Old 11-20-2002, 09:57 AM
Bookerv12 Bookerv12 is offline
Default Best CD burner options
I am on an HD2 system.
Just getting ready to upgrade to a new Mac.
On my trusty old G4 400, I have been using a Glyph/Plextor tabletop scsi CDRW for backing up and burning audio CD's.
It has a couple billion miles on it now and is beginning to screw up, not to mention the slow (4X) write speed.
My question is...
What would be the best modern replacement?
What is everybody using?
I need more speed for Data backup.
I have used the plextor for a long time because it has been absolutely bulletproof.
My new room has a seperate computer closet and I would like to have the burner in the control room.
I'm not too knowledgeable on this subject, so you guys tell me....
Thanks again.
Booker
bookerv12
Old 11-20-2002, 11:17 PM
Kenny Gioia Kenny Gioia is offline
Default Re: Best CD burner options
You can get a 40X firewire CD Burner for about $229.00 now. They work great.
I can burn 4 or 5 songs in about 30 seconds.
Nice.
No more bathroom breaks waiting for CD's to burn
Old 11-21-2002, 06:40 AM
Thanks Produceher,
Is there any brand/model that you have had good luck with?
Booker
bookerv12
Old 11-22-2002, 12:04 AM
I have an EZ Quest that's workin Great.
Old 11-22-2002, 09:28 AM
Allan Speers Allan Speers is offline
Burning at 40X is asking for trouble, even with a large cache. You will get more duplication jitter, not to mention bler errors. the resulting cd's will sound slightly edgy, and will be more prone o skipping on some players.
Get the new Yamaha F-1 burner, and use it's "advanced audio" mode for all critical audio. I have done blind testing on this vs two other burners, and the Yamaha cdr's definitely sound closer to the source audio. -really. [img]images/icons/cool.gif[/img]
BTW, the F-1 will burn at 44X if you want, but when you select "advanced" mode (which make the pits and lands a bit longer and thus easier to read) it analizes the blank cd installed and picks the optimum speed based upon a data-base created by their techs in Japan. With most media this is 4X speed.
Old 11-22-2002, 09:51 AM
Dutchmuzik Dutchmuzik is offline
Speer, what CD software do you use, I am still stuck in Masterlist CD world, I would like to stay with SCSI, seems more reliable. But I am thinking about getting Waveburner Pro
Old 11-22-2002, 05:55 PM
audiaudio audiaudio is offline
<font size="2" face="Verdana, Arial">Speer,
Have you used the F1's "Disc Tatoo" feature to burn text/graphics onto a CD?
Does it work well? Is it fast and painless?
Does it compromise audio quality in any way?
Thanks.
 iMac i7 2020 Monterey 16GB HD Native Thunderbolt
Old 11-22-2002, 06:55 PM
Dopamine Dopamine is offline
I'm also curious about that Yamaha F1? Does it label and burn in the same pass? what is the maximum size of the "tatoo".
http://www.phuturetrax.com
Old 11-22-2002, 08:16 PM
N-G-NEER N-G-NEER is offline
Plextor make a 48-24-48 Mac compatable.
Smokes it's so fast it scares me
Old 11-22-2002, 08:42 PM
Dutchmuzik,
You must use either the newest toast lite, or something called "Nero." both are bundled with the f-1. That's a point about MLCD. I rarely have to edit PQ codes, so toast works fine for me.
Digi will probably not update MLCD's burner support for anothe 10-16 months, if past performance is any indication. i would imagine that Jam already supports the F-1, though i haven't bothered to get the latest version yet
audiaudio. Dopamine,
I haven't tried disc tattoo. It takes about 15 minutes per disc,(seperate pass) and also uses up quite a bit of real estate. definitely a cute trick for Mom and Pop, but no for pro use.
My CD-burner...please help me!!! Elli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-03-2002 04:54 PM
burner for G3 B&W (rev 1) caz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-29-2002 11:11 PM
Wave Burner-Type software for Lacie Burner? Loftman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-04-2002 11:08 AM
CD burner Soberphobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-19-2001 08:28 PM
Current burner options for a 9600? KML Digidesign Hardware & Software 0 12-19-2000 05:42 PM
