Old 04-27-2003, 02:20 AM
6969 6969 is offline
Default Routing audio to Aux question
Hello
I have successfully figured out how to send a single track to an Aux track to take advantage of plug-ins,reverb or whatever on it. [img]images/icons/smile.gif[/img]
My question is...How do I send more than 1 track of audio to a SINGLE Aux track and how many tracks of audio can you send to a single Aux track.Any input on this would be appreciated greatly.
DJ
6969
Old 04-27-2003, 03:29 AM
Sugarnutz Sugarnutz is offline
Default Re: Routing audio to Aux question
Setup a send send on your audio track and select a bus as it's destination, IE: bus 1, you can do this on as many audio tracks as you like using the same bus. Then create an aux track selecing it's input as that same bus. Insert a reverb on that aux track and there you are. Every audio track you setup this way will be passed through this reverb. You can adjust the amount of reverb on each audio track by clicking on the little send icon on each audio track and adjusting the pop-up fader. Typically I use a mono bus as the send to a mono aux track I created and then insert a stereo reverb on that mono aux track, which then ends up with a stereo output to your mix. Make sure the reverb is set to 100% wet and set the mix level on the aux track to "0", works like a champ. You can do this with reverbs, delays, whatever. Hope this helps...
HD Native Thunderbolt
HD6 Accel in Magma PE6R4 Expansion Chassis
PT HD 10, 11, 12, Ultimate 2018, 2019
Cubase 9.5 Pro
Vienna Ensemble Pro 7
Icon D-Command
HD Omni
192 Analog I/O 8 in/8 out/Digtal I/O
192 Analog I/O 8 in/Digital I/O
Two 192 Digital I/O
Apogee Rosetta 800, AD16X & DA16X (All wth X-HD cards)
Antelope Zen Studio+ Thunderbolt
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.3
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
MacOS 10.14.5 Mojave
GIGABYTE GA-Z97X-UD7 TH
Intel Core i7-4790K 4.4 GHz
32 GB of DDR3 1600
EVGA GTX 760 Video Card
OS X 10.13.6 High Sierra & Win 7 Pro 64 bit
Dynaudio BM5 Mk III
B&W 604 s2
800W 15" Ported Subs
McIntosh MC-7106 Bridged ~ B&W
Hafler P7000 "Diablo" ~ Subs
Old 04-27-2003, 09:50 AM
pilot57 pilot57 is offline
Every day I click on this page for a cool tip,
and buta-bing heres 1 im gonna use today!
Thanks!
Hal
Pilot57
Http://www.pilot57.com
Rocking the bay-area
Old 04-27-2003, 11:08 PM
Thanks
I'll be trying this out soon.
DJ
6969
Core audio manager routing question - iTunes to b15&16? Blues Bird macOS 4 07-05-2013 04:46 AM
Routing question -- how can I do this? WildHoney Pro Tools TDM Systems (Mac) 6 08-15-2006 05:44 PM
Routing question Deluxomatic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-05-2005 11:54 AM
002 audio routing question (mirroring to SP/DIF) EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-28-2004 08:59 AM
001 Cue Mix Routing Question Nash BBQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-03-2002 11:03 AM
