Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-13-2019, 09:26 PM
Cryos's Avatar
Cryos Cryos is offline
Default 2019.10 ULTIMATE possible VOLUME bug
in the Re-link window under Volumes... All my drives are showing up except my SSD drive.. Open up the same relink window in 2019.6 and SSD drive show up under Volumes.
Hows that possible?!
my SSD drive is in an external USB 3 chassis. So to re-cap..Re-Link Window/ VOLUMES PT 2019.6 sees the drive no prob. 2019.10 does not see the drive
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 11-14-2019, 02:42 AM
Wire57 Wire57 is offline
Default Re: 2019.10 ULTIMATE possible VOLUME bug
At least you got PT 2019.10 installed and running, I am still stuck with that update failure. (I described that in "PT 2019.10 won't install" - http://duc.avid.com/showthread.php?t=406991 - here.)
So how did you manage to update PT, please? and which Windows version are you running?
Thankx.
Old 11-17-2019, 06:42 AM
Cryos's Avatar
first off I'm running it on Apple not Windows, so I wouldn't know anything about installation failure.
However regarding the issue I experienced, i can't be certain but this odd volume not showing up seemed to happened when I accidentally created a new session on my internal system HD. When I realized what i had done and I then created the project on the missing SSD drive after which 2019.10 saw the drive. very odd. I have not experienced this since....
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
PT 2019.6 wants to access my... priorytools Pro Tools 2019 4 11-14-2019 01:52 AM
2019.5 Ultimate on a Mac Pro 5,1 DenverAudioGuy Pro Tools 2019 44 05-28-2019 04:25 AM
Pro Tools Ultimate 2019.5 and HDX Avid Technical Alerts 0 05-09-2019 02:55 PM
D-Command & PT Ultimate 2019.5 rmccam ICON & C|24 5 05-09-2019 01:49 PM
