Old 09-22-2019, 05:23 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Suddenly PT won't load Plug-Ins because not valid 64-bit
try re-installing iLok.com software.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.10 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds/upkeep
Old 09-22-2019, 08:04 PM
I think folks have tried that to no effect. Something bad is going on here. Avid support has cases open Now...
Old 09-22-2019, 11:49 PM
the19thbear the19thbear is offline
Default Suddenly PT won't load Plug-Ins because not valid 64-bit
It also happens with plugins that don’t require and Ilok.
I haven’t tried reinstalling the ilok software though.
Hope it gets fixed soon
Old 09-24-2019, 05:22 AM
Pete Gates Pete Gates is offline
Yes, please report back on any news from Avid or discoveries you make. Trashing prefs can make things worse in one case - plugins are cached and not verified by Pro Tools to speed start-up. When you trash prefs that plugin cache is (optionally) cleared so pro Tools does a deep scan of all plugins and that can seem to create a problem if there are problematic plugins - the underlying problem was already there, you just couldn't see it.
Cheers,
Pete
Old 09-24-2019, 06:09 AM
Southsidemusic's Avatar
Happens here with KUSH plugins on ilok.
Best Regards
Christopher
South Side Music Group
WEBHOME
  #16
Old 09-26-2019, 06:34 PM
hugoleitao hugoleitao is offline
Originally Posted by spoons View Post
OS 10.12.6 , PT 2019.6.0
Suddenly on booting up a session I had a AAE 7058 unauthorised plugin error. So I trashed prefs.
Now I have a few plug-ins that won't load because "they aren't valid 64bit" ? They have worked fine up to this point?
The only thing that's changed is I upgraded my iPhone to iSO13. When i plugged it into my mac I had a message come up saying that to connect my iPhone I bit of software had to download, which it did. Surely not connected ?
Any ideas ? I've trashed prefs (made it worse) and ran first Aid on the boot drive.
Having exactly the same problem, McDsp, Nugen, Exponential Audio won't load
What a nightmare I'm in the middle of a session...never saw anything like this and I've been using PT since version 4...
  #17
Old 09-28-2019, 02:15 AM
spoons's Avatar
spoons spoons is offline
So I never got to the bottom of this problem. Had too much work on so used time machine to roll back to before I plugged in my phone and I’m up and running again.
Told Avid support and they closed my case. To be fair though the Mac Pro / chrome problem happened so they probably moved onto that.
I made them aware of this thread.
Rich.
Richard Spooner
www.spoonsound.com
  #18
Old 09-28-2019, 04:47 AM
The rest of us are pretty much screwed. My backup is old and I would hate to reinstall everything. It’s probably a simple patch/fix that takes 5mins download (once it’s actually made).
I will, for now, live without the missing plugins. Hope that they fix it within the next couple of weeks
  #19
Old 09-28-2019, 04:59 AM
There have been many times where a complete install of everything (operating system, etc.) has helped people with the strangest of problems and even cleared up some issues they didn't know they had. Not to mention things running a lot better in general.
Jack
QAPLA!
  #20
Old 09-28-2019, 05:15 AM
JFreak's Avatar
JFreak JFreak is offline
Yes, and simply opening Activity Monitor and taking a look of the processes that are running... the list of helper processes etc. first of all take a huge chunk of the available memory, so if you're running bare minimum of 8GB and some Adobe CC process takes one GB, Avid AppMan half a GB and so on, you know you either need more memory or a clean start.
Janne
falcon failed to load because it is not a valid 64 bit plugin fourthtunz Pro Tools 2019 1 07-09-2019 08:36 AM
"Not valid 64 bit AAX plug-ins" - almost all 3rd party plugins suddenly corrupt noiseboyuk Pro Tools 2018 10 12-18-2018 05:22 AM
Some UAD plugs "failed to load...not valid 64 bit AAX..." sfsonarboy AAX Plug-ins 3 02-04-2016 06:55 PM
Pro Tools Suddenly takes up to 4 minutes to load ashm macOS 5 12-31-2010 05:17 PM
PT 7.4 Suddenly Does Not Load Toonvox Pro Tools TDM Systems (Win) 7 07-15-2009 02:11 AM
