Old 03-29-2017, 04:04 AM
Dj-Ike Dj-Ike is offline
Default PT 12.7 + Sierra 10.12.4
Updated to the new MacOs on my MBP. No issues so far.
PT18, Avid S3, LogicX, DP8, OS10.12.6, Mac Pro 2013 3.5GHz/32GB ram/SSD=14T, Macbook Pro 17" i7/16GB/4T Samsung EVO SSD, Avid S3, Digi 003, UMC404HD, A.I.R., DSF Plugs, EW Collection, McDsp collection, Slate Digital collection, Softube collection, IK Multimedia Bundle, Komplete 11 Ultimate, Reason 8, Waves Mercury/SSL400/Abbey Roads, Wavearts5, Avox, Yamaha 01V96i, NI S61+Maschine Studio, DP8, Midixpress XT, Digital Timepiece, Urei 1178, S760, P2K, ect..
Music is the Message
Old 03-29-2017, 04:53 AM
jamesleonard jamesleonard is offline
Default Re: PT 12.7 + Sierra 10.12.4
Hello Dj-Ike.
Will the new update fix the problem which relates to: 'mini grand' (see: Virtual instruments, AIR Mini Grand: no 'long' sound, just short notes post?)
Also... you say you have 003 - and this works ok too?
James
Old 03-29-2017, 05:15 AM
JFreak's Avatar
JFreak JFreak is offline
Mini Grand has a workaround. Take a look at Virtual Instruments forum
Janne
Old 03-29-2017, 08:07 AM
TrentWilliams TrentWilliams is offline
Can confirm, no issues from here either. Tested on a portable workstation then moved my main machine over. In the middle of a heavy 35 minute post-production mix and haven't run into a single error since updating.
Pro Tools 2019.6|Ultimate, UAD Apollo 8, UAD Octo+Quad Satellite, UAD Apollo Twin Quad Core, Focusrite 8PreXiMac 27" Late 2013 - 3.5GHz i7 - macOS 10.14.4 • RAM 32GB DDR3, GPU NVidia GTX 780M 4GB
Old 03-30-2017, 01:45 PM
fourthtunz fourthtunz is offline
bump!
I'd like to see how this combo is running too but I'll still upgrade to this combo!
Old 04-07-2017, 07:36 AM
lBeaman lBeaman is offline
I am also running 12.7 + 10.12.4 combo on a new Mac Pro and everything seems to be fine so far. I am running into intermittent "beachballing", but that may be unrelated; it is a brand new setup.
Old 04-07-2017, 02:05 PM
I'm getting intermittent beach balling too, only lasts for 20 seconds then back on track again. I think this combo has been the most stable i've seen Pro Tools (at least on my rig) for a long time.
On another note - i'm looking forward to the incoming update later this month that will (should) fix excess CPU usage from Eucon.
Old 04-07-2017, 02:44 PM
Tao Jones Tao Jones is offline
I'm on Sierra 10.12.4. I was on Pro Tools 12.5.2 and went to 12.7.1, both versions suffered from Midi Note Editor lag. i.e. Dragging note(s) while the play head scrolls by would grind the GUI down AND the note(s) being dragged. The lag didn't go away after a fresh install of Sierra and Pro Tools so I rolled back to 12.4 and everything has been pretty smooth so far. I'm on a new Mac Pro 8 Core with 16g RAM and 500g flash drive.
Old 04-10-2017, 07:45 AM
Were you able to track down a possible source? I've been doing some testing and have just found this morning that disabling the video engine seems to have helped. Can't confirm yet as the issue is so intermittent.
Old 04-10-2017, 01:48 PM
I'm using Video Slave at the minute, so have been using PT with the video engine turned off. Still beachballs every now and again, but it really doesn't bother me. It really is only for 10 to 20 seconds at a time then it carries on.
I think it's from the Eucon engine tbh, but can't confirm.
The takeaway from this I think is:
- Remove Avid App Manager
- Update your Avid Codecs
- Turn Wifi off
- Turn video engine off
- Run 12.7.1 and OS 10.12.4
and you'll have a good time.
HDX with PT non HD on Sierra ? JJdelRio Pro Tools HDX & HD Native Systems (Mac) 14 04-26-2017 08:47 AM
PT 12.7 Sierra 10.12.2? off the wall macOS 2 01-17-2017 02:49 PM
Can't get Sierra on 5,1 Mac Pro Carl Lie Pro Tools 12 21 01-06-2017 05:46 PM
HDX and Sierra Jeffrey Talbot Pro Tools HDX & HD Native Systems (Mac) 5 11-16-2016 04:21 PM
OSX Sierra jack s. macOS 25 11-05-2016 05:51 AM
