Old 12-15-2015, 02:17 PM
1Youngc_ 1Youngc_ is offline
Default Heeeeellllppp Please Current Playback
I Have Pro Tools 11 And I Just Updated My IMac To OS X 10.11.2 And Since Then When I Load My Pro Tools It Says the current playback engine does not support the sample rate of 48kHz. And If I Start A New Session It Says I Do Not Have Any Input Or Output Sound Devices Set But Everything Has Been Left The Same I'm Using A M Audio Fast Track Interface Can Someone Please Help Me!
Old 12-15-2015, 03:34 PM
priorytools priorytools is offline
Default Re: Heeeeellllppp Please Current Playback
Try trashing all the pro tools prefs.
User/lib/preferences/avid.
You may also need to check for driver updates for your Fast Track.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 12.5 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.9.1 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 12-15-2015, 03:53 PM
Oh dear. Take a look in the PT12 discussion.
Old 12-17-2015, 06:45 AM
Make sure your interface is compatible with ElCapitan and that you have the proper drivers for it installed. Also make sure your interface is turned on when you start the computer. Finally hold down the 'n' key on the computer keyboard when starting PT and you can select the audio interface of your choice. When PT says 'the current playback engine does not support the sample rate of 48 KHz' it's not seeing your regular interface. Happens to me once in a while when my iMac doesn't see the 11 Rack interface I use even though it's turned on when starting the computer.
Jack
QAPLA!
The Current playback Engine.... Vercingetorix Eleven Rack 3 11-27-2015 12:04 PM
The Current Playback engine....Grrrr orangefridge Pro Tools 11 1 01-26-2015 11:40 AM
PT could not init the current playback device SvK Pro Tools 9 3 01-04-2011 10:24 PM
Current playback engine... Gonk Pro Tools M-Powered (Win) 0 04-28-2010 02:55 PM
Current Playback Engine icenet Pro Tools TDM Systems (Mac) 3 09-04-2006 07:34 PM
