  #41
Old 07-04-2016, 09:20 AM
Default Re: PT 11 won't import audio
There you go, a lesson to all of us to Google the exact error message. .....
  #42
Old 07-04-2016, 09:54 AM
studiorecording studiorecording is offline
Thank you Daniel.
  #43
Old 07-07-2016, 01:27 AM
ursolus ursolus is offline
Default Re: Can't import audio
My error states: Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/Pro Tools/Cfd_Import/AudioDialofMacOS.mm"'line 559
Pro Tools recommended that you keep your session folder on an external hard drive as far as I can remember.
  #44
Old 07-07-2016, 02:13 PM
jcasasf jcasasf is offline
Default Re: Can't import audio (Assertion Error Line 559) with Pro Tools 11 on El Capitan
I have been working with Protools 11.3.1 and El Capitan for almost 3 weeks and I did not had any problems importing audio. I did have some other issues and I installed same version of Protools again and so far I have not been able import any audio of any type. This is very annoying because is Protools 11 compatible with El Capitan, YES or NOT?
Everyime I try to import audio I get the same message... Can't import audio (Assertion Error Line 559) with Pro Tools 11 on El Capitan...
  #45
Old 07-07-2016, 06:29 PM
Chief Technician's Avatar
Exclamation Re: Can't import audio (Assertion Error Line 559) with Pro Tools 11 on El Capitan
NOT.
  #46
Old 07-08-2016, 04:54 PM
MXShuffle MXShuffle is offline
Default Re: Import audio error message
Originally Posted by Chief Technician View Post
Use drag-and-drop instead of the Import command. It is unlikely that Avid will fix this for PT v11.3.x.
I've run into this same problem. I've recently done a full uninstall/reinstall of PT 11.3.2 and the problem persists. I work as a music editor so previewing tracks in the import window is a huge part of my workflow. Dragging and dropping is not a viable option. Are there any known fixes for this?
I'm on a Mac Mini (Late 2014), running OS 10.11.5, running PT 11.3.2.
  #47
Old 07-09-2016, 06:38 AM
Arrow Re: Import audio error message
Downgrade your OS to 10.10.5 (or earlier) or upgrade to PT 12.3.1 (or later).
  #48
Old 07-20-2016, 10:39 AM
therecliner therecliner is offline
Default Error message regarding " Audio Import " solution?
Hey,
Recently tried importing some audio in a session this past week and I was hit with this:
"Could not complete the Import Audio command because Assertion in "/Volumes/Development/124699/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559."
Unfortunately I am unable to import any sessions or tracks. I have to drag them in through iTunes and then the whole session gets distorted.
Any suggestions or have seen this error and know how to proceed?
E,
iMac OS X El Capitan version 10
Pro Tools 11
Apollo Twin interface
  #49
Old 07-20-2016, 01:39 PM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Default Re: Error message regarding " Audio Import " solution?
Have you not read the sticky at the top of the page?
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 431.86- 2 x Internal WD Blacks + MSATA card - Davinci Resolve 16.1 - Canon HF G40
  #50
Old 07-20-2016, 05:22 PM
musicman691 musicman691 is online now
Originally Posted by therecliner View Post
Hey,
E,
Pro Tools 11
Going by the minimal system info you give first off PT11 is not and will never be qualified to work with ElCrapitan - it's that simple. What is ElCrap version 10? Never heard of that.
Are you trying to import off a drive that's formatted for Windows? That's a recipe for disaster. Is the drive you're importing from going into sleep mode? That's another no-no.
What exact version of PT11 are you using?
Jack
QAPLA!
Any ideas how to fix this error during audio import: Assertion... line 603. luism Pro Tools 12 3 03-15-2018 12:36 AM
Pro tools 9 assertion error cannot import any data blazinbk Windows 4 04-30-2012 07:52 PM
Can't Import Audio from QuickTime Video -- Assertion Error David Ziegler Pro Tools 9 28 09-18-2011 05:09 AM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 10:38 AM
