Old 02-13-2015, 04:15 PM
2224 2224 is offline
Default re: heat [solved]
Why is heat not showing in PT 11.0? Not even the little dock where it's suppose to be in the lower right corner of the mix window,or in the preferences under processing.
JAMAICAN I IS
2008 2009 and 2010 Mac Pro 8 core with
64 GIG memory with 9 terabyte of hard drive space
blue ray player
HDX 1, 2 16X16 interfaces
sync I/O.
Old 02-13-2015, 05:31 PM
Josh Voyles's Avatar
Josh Voyles Josh Voyles is offline
Default Re: heat
Heat is AAX DSP only and requires the HDX core cards.
Old 02-13-2015, 05:33 PM
Default Re: heat
Of course, I responded before reading your signature block.
Looks like you have HDX cards installed.
I thought you were running PT11 and not 11HD.
Old 02-13-2015, 05:47 PM
Default Re: heat
LMAO,no worries, I do stuff like that all the time,but what you Sid made me think and I think I got it now.
Thanks
JAMAICAN I IS
blue ray player
sync I/O.
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 11:17 PM
bought heat how to install [solved] Filmusic Pro Tools TDM Systems (Win) 7 02-09-2013 08:43 AM
re heat on 10 2224 macOS 9 08-12-2012 06:11 PM
Heat midnightsun Pro Tools TDM Systems (Mac) 2 03-09-2011 02:52 AM
SOLVED>>Need HELP, SUPER ASAP.< audioindo Pro Tools TDM Systems (Mac) 18 04-21-2007 06:43 AM
