Old 01-08-2015, 10:44 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Major Problems with PT11 and PT10
Same with Windows 8/8.1 and Pro Tools 11. As the OP stated, some versions allow multi-client use of the PT interface and some don't. PT 11 doesn't.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-08-2015, 10:59 AM
8dB.co.uk 8dB.co.uk is offline
If you wish to share your 003R between ProTools and system audio, just make sure your Windows audio setup is the same as the settings you wish to usr ProTools at. So, if you want 48K 24bit, go to windows control panel, and select sound. Click on your 003R and select configure. There you can set the system sample rate and bit depth. Make sure you do all this before starting ProTools. Untick the box that says something like "applications can take exclusive control". Also, ensure that nothing with a conflicting sample rate - say am audio CD, is playing (even paused) when opening ProTools. This used to work on my 002R and Mbox2. However, once ProTools fires up, it did tend to lock out the system audio.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 01-08-2015, 08:28 PM
DC-Choppah DC-Choppah is offline
Right. There is no problem sharing your interface for Protools and for listening to CDs, YouTube videos etc, by setting it as the system default, as long as you manually go into the control panel everytime to check if Windows has changed the setting from what you normally use in your sessions.
Windows 7 will change these settings depending on the material being played automatically. But infuriatingly, it does NOT set it back to what it was before! Worse yet, it prevents ProTools from making the change itself. So you have to go do it manually.
What I do now is I have a little macro that runs automatically when I click the ProTools icon. The macro goes and resets the windows control panel to my standard session parameters (24 bit / 48KHz) then launches ProTools.
DC-Choppah's Project Studio:
ASUS P5Q Pro Turbo /Intel Pro 2 Quad Core-rackmount PC
Windows 7 professional 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
M-AUDIO FastTrack ULTRA 8R Interface
Roland RD-300 / Novation XiO Keyboards
Mackie 12 channel Analog Mixer
Adam A8X monitors
Estonia Parlor Grand Piano
Yamaha Studio Drum kit
https://soundcloud.com/dc-choppah
Old 01-14-2015, 05:49 PM
100grit 100grit is offline
Originally Posted by DC-Choppah View Post
This seems to be a Windows 7 thing, not a Pro Tools thing.
When the device is set to default, Windows 7 does not release it so that ProTools can change its settings.
Well, PT 10.3 with my Windows 7 was fine using my Digi 003r as my main pc defaut audio. But not with PT 11.3 and I can remember all the other PT upgrades about half would workfine and the other half would not. Go figure lol
major PT11 delay compensation weirdness. frozenintime macOS 18 02-18-2015 06:38 AM
Any problems if I co-install PT11 (not HD) alongside PT10 HD? bashville macOS 5 10-13-2014 03:54 AM
Export Multichannel Interleved Files - Major Bug in PT10 evs Post - Surround - Video 40 08-18-2012 07:49 PM
Mbox 2 with PT10 = major problems. YouMeOh macOS 5 03-17-2012 03:48 PM
Dubbing Major Pix, Major Problems BigBobMXMan Pro Tools TDM Systems (Mac) 0 07-15-2001 02:43 AM
