Tried to upgrade install from PT10.2 to PT10.3. Will not install. So, went to install PT11.3
Installed nicely but won;t allow me to open any of my files - "The current Playback engine does not support a sample rate of 48 kHz." Huh? Why not? Did a search and can't seem to find any answers. I also can't create a new session because the sample rate box is greyed out. Using a Digi003r (hot rodded by Black Lion Audio) which has been flawless thru the years. Any ideas??? |
not enough info
please review the Help Us Help You link at the top page
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements Thank you, Craig |
Craig, there's enough information. My specs are fine. This problem has already been documented in other posts. I tried their fixes to no avail. Please give me a fix!
What OS version? Do you have PT10 installed? Which one? What hardware drivers have you loaded? Mac or Windows?
What fixes have you tried? From Avid: Pro Tools 11.x co-install with Pro Tools 10.x is only supported using Mac OS X 10.8.5 Mountain Lion
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
![]() Quote:
you want help, follow the rules, if not please leave us alone
Sorry, I gave you Mac advice since you were not clear.
Use the 003 driver. I believe a new one was recently posted. Have you tried opening a blank session at 96, closing and then opening your session?
I am familiar with this problem with Windows 7 and have a few threads about it.
Try this quick fix to confirm that your problem is the same as mine. Close ProTools when you get the error. Go into the Windows 7 control panel and set your internal PC audio device to be the default. Make sure that your ProTools audio interface is NOT set to the default. Re-launch ProTools.
DC-Choppah's Project Studio: ASUS P5Q Pro Turbo /Intel Pro 2 Quad Core-rackmount PC Windows 7 professional 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle M-AUDIO FastTrack ULTRA 8R Interface Roland RD-300 / Novation XiO Keyboards Mackie 12 channel Analog Mixer Adam A8X monitors Estonia Parlor Grand Piano Yamaha Studio Drum kit https://soundcloud.com/dc-choppah |
![]() Quote:
Gigabyte X79/intel i7 3930K, 32GB RAM, DIGI003 Rack https://www.facebook.com/search/top/...0sound%20works The better I drink...the more I mix..... ![]() BTW, my name is Dave, but most people call me.........................Dave |
![]() Quote:
This seems to be a Windows 7 thing, not a Pro Tools thing.
When the device is set to default, Windows 7 does not release it so that ProTools can change its settings.
major PT11 delay compensation weirdness. | frozenintime | macOS | 18 | 02-18-2015 06:38 AM |
Any problems if I co-install PT11 (not HD) alongside PT10 HD? | bashville | macOS | 5 | 10-13-2014 03:54 AM |
Export Multichannel Interleved Files - Major Bug in PT10 | evs | Post - Surround - Video | 40 | 08-18-2012 07:49 PM |
Mbox 2 with PT10 = major problems. | YouMeOh | macOS | 5 | 03-17-2012 03:48 PM |
Dubbing Major Pix, Major Problems | BigBobMXMan | Pro Tools TDM Systems (Mac) | 0 | 07-15-2001 02:43 AM |
