Old 12-22-2014, 03:51 PM
100grit 100grit is offline
Default Too Frightened to Install 11.3
Just bought the upgrade from PT10. I'm about to finish my 9-song record (has to be done Dec 31, 2014) but am very concerned that everything will mess up if I install right now, meaning, losing active plugins, non smooth install etc. Maybe I should mix/master 100% save as WAV files and then install 11.3? Help!!!
Old 12-22-2014, 04:00 PM
priorytools priorytools is offline
Default Re: Too Frightened to Install 11.3
Do you need to go to 11 to finish the project ?
If not… don't… finish project, then make the move at you leisure
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 12.5 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.9.1 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 12-22-2014, 04:24 PM
I don't need 11 to finish this project. I just wanted to see if 11 offered anything sonically to my existing PT10 sessions.....
Old 12-22-2014, 04:59 PM
noiseboyuk noiseboyuk is offline
Absolutely. PT11's advantages are really workflow-based anyway. Concentrate on the album, not on tech nightmares. You can have those on Jan 1st...
Guy Rowland
www.guyrowland.co.uk
PT 2019 Ultimate; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Old 12-22-2014, 05:44 PM
writeroxie writeroxie is offline
Don't do it!
Protools 12.4.0 :: MacPro 5,1 "Westmere" 2x2.4gHz 8-core 32GB Ram
Sierra OS 10.12.6 :: Apogee Quartet
Old 12-22-2014, 07:43 PM
anyone wanna hear a short clip of one song?
Old 12-22-2014, 07:45 PM
wpawley wpawley is offline
Sure, I'd love to hear some.
Old 12-22-2014, 07:46 PM
Eric Lambert's Avatar
Nope, no sonic advantage to 11. Stick with 10 until the mission critical workload is done, then upgrade when you have time to risk a few bumps in the road - there probably will be bumps.
Old 12-26-2014, 01:31 PM
Silent Sentinel Silent Sentinel is offline
I'm in the exact same boat (though my project can run into January or Feb). Was considering making the purchase and then waiting until after the album was done to install. Glad to hear I'm not the only one w/ the jitters...
Question though (when I get around to doing the PT11 install), if I'm already running PT10, can my existing install run alongside with PT11, or do I have to uninstall my current PT10 and install the the PT10/PT11 upgrade? I'm guessing the latter, but just wanted to make sure.
Thanks,
~ Mark
Old 12-26-2014, 01:38 PM
Benoni's Avatar
Benoni Benoni is offline
Thanks,
~ Mark
You should be able to leave your current install of PT10. Here is the approved Co-Install page: http://avid.force.com/pkb/articles/e...ll-Information
Install PTHD 8.1.1 udater on Win7x64 and says valid install not found 8.0.3 is there rnygren Pro Tools TDM Systems (Win) 2 10-25-2014 11:58 PM
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 05:39 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 08:23 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 12:16 PM
Can't install Pro Tools LE - Insert disc but no option to install Paul McConnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2010 09:13 AM
