  #251
Old 10-13-2019, 07:55 PM
Oliver M Oliver M is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Here's some simple code to open a PT session with the Finder:
Code:
set mySession to (path to documents folder as text) & "Pro Tools:mySessions:Test_Session.ptx" as text
tell application "Finder" to open mySession using application file id "com.avid.ProTools" as alias
  #252
Old 11-03-2019, 03:38 PM
Originally Posted by echoesoflife View Post
Thanks Oliver, duly noted. This makes sense. I will implement these ideas and will report back. Thanks again.
Any progress?
  #253
Old 11-03-2019, 05:08 PM
echoesoflife echoesoflife is offline
Originally Posted by Oliver M View Post
Any progress?
Hi Oliver, thanks for checking in, appreciate it.
Yes, I made some significant progress. The script is still not operational, I am looking to debug it.
Current issues:
- When I open just one file, the script performs well
- When I try opening more than one file, the script wouldn't click Don't Save button. Also sometimes the script wouldn't open Memory Locations - which somehow works for one file
I will spend more time debugging the script.
Here's the current version for the reference:
Code:
property cliclickCLIPath : missing value
property shortDelay : 0.1
property medDelay : 0.3
set cliclickCLIPath to "usr/local/bin/cliclick"
set theFolders to {}
repeat
	try
		set theFolders to theFolders & (choose file with prompt "Choose your PT files to bounce. Choose Cancel when finished with all folders" with multiple selections allowed)
		get theFolders
	on error
		display notification "Exiting"
		exit repeat
	end try
end repeat
get theFolders
set i to 0
set aRow to 0
set bRow to 0
set mySession to {}
repeat with i from 1 to (count of theFolders)
	set mySession to item i of theFolders
	delay shortDelay
	tell application "System Events"
		tell process "Pro Tools"
			try
				set frontmost to true
				-- Open Memory Locations window if it is not open already
				if not (exists window "Memory Locations") then
					click menu item "Memory Locations" of menu "Window" of menu bar item "Window" of menu bar 1
					repeat until exists window "Memory Locations"
						delay shortDelay
					end repeat
				end if
				-- Set variable for Memory Locations window
				set mlWindow to (1st window whose name contains "Memory Locations")
				delay shortDelay
				tell mlWindow
					delay shortDelay
					-- Maximize window
					click button 10 of mlWindow
					try
						-- click "Start"
						set aRow to row 1 of table "Memory Locations"
						tell aRow
							set {xPosition, yPosition} to position
							set {xSize, ySize} to size
							my cliClick("c:" & xPosition + (xSize div 2) & "," & yPosition + (ySize div 2))
						end tell
						-- click "End"
						set b to count of row of table "Memory Locations"
						set bRow to row b of table "Memory Locations"
						tell bRow
							key down {shift}
							delay shortDelay
							key up {shift}
						end tell
					on error e number n
						tell application "Pro Tools" to display alert "An Error Occurred" message e & " (" & n & ")" buttons {"Cancel"} default button 1
					end try
				end tell
				-- Press ⌥⌘B
				tell application "System Events" to key code 11 using {option down, command down}
				-- Press "Bounce"
						try
							-- HERE TO ADD ALL THE VARIABLES
							click button "Bounce" of window 1
							delay shortDelay
							keystroke return
							repeat until exists button "Don't Save" of window 1
							end repeat
							delay shortDelay
							click button "Don't Save" of window 1
						end try
					end tell
				end tell
				--	end repeat
			end try
		end tell
	end tell
end repeat
on cliClick(process)
	do shell script quoted form of cliclickCLIPath & " -r " & process
end cliClick
Pro Tools 2019, Hackintosh High Sierra
  #254
Old 11-17-2019, 07:08 PM
Hi all,
Looks like I was able to make the first version of the automatic bounce script to work.
Here is the code.
I will continue debugging it and adding small improvements.
Kindly let me know if it's usable on your end. Highly appreciate all your help and attention along the way.
Code:
repeat
	try
		get theFolders
	on error
		exit repeat
	end try
end repeat
get theFolders
set i to 0
set aRow to 0
set bRow to 0
set mySession to {}
	set sessionName to name of (info for mySession) as string
	set sessionNameTrim to trimText(sessionName, ".ptx", "end")
	delay shortDelay
-- TO FINISH HERE - to click Don't Save if PT project is already open
			if exists button "Don't Save" of window 1 then
			end if
			if i is not equal to 1 then
				if not (exists button "Don't Save" of window 1) then
					end repeat
				end if
			end if
			try
						--	key code 87 using {command down}
						delay shortDelay
					end repeat
				end if
				-- Maximize Memory Locations window for script to be able to click on each marker
				delay shortDelay
				tell mlWindow
					delay shortDelay
					-- Maximize window
					try
						-- click "Start"
						tell aRow
						end tell
						-- click "End"
						tell bRow
							key down {shift}
							delay shortDelay
							key up {shift}
						end tell
					on error e number n
					end try
				end tell
				-- Press ⌥⌘B
				-- Press "Bounce"
						try
							--	Change name of bounced file to Session Name Trim
							set bField to text field 1 of window 1
							tell bField
								delay shortDelay
								my cliClick("c:" & xPosition + (xSize div 10) & "," & yPosition + (ySize div 2))
								key code 0 using {command down}
								keystroke sessionNameTrim
							end tell
							delay shortDelay
							keystroke return
							-- Wait until bounce finishes
							repeat until (static text "Bouncing..." of window 1 exists)
							end repeat
							repeat until not (static text "Bouncing..." of window 1 exists)
							end repeat
						end try
					end tell
				end tell
			end try
		end tell
	end tell
end repeat
if i is equal to (count of theFolders) then
			key code 13 using {shift down, command down}
			end repeat
		end tell
	end tell
end if
end cliClick
on trimText(theText, theCharactersToTrim, theTrimDirection)
	set theTrimLength to length of theCharactersToTrim
	if theTrimDirection is in {"beginning", "both"} then
		repeat while theText begins with theCharactersToTrim
			try
				set theText to characters (theTrimLength + 1) thru -1 of theText as string
			on error
				-- text contains nothing but trim characters
				return ""
			end try
		end repeat
	end if
	if theTrimDirection is in {"end", "both"} then
		repeat while theText ends with theCharactersToTrim
			try
				set theText to characters 1 thru -(theTrimLength + 1) of theText as string
			on error
				return ""
			end try
		end repeat
	end if
	return theText
end trimText
  #255
Old 12-01-2019, 01:32 PM
Hi Michael,
this looks promising. 👍
I will check it out as soon as my time allows. I am usually pretty busy around this time of the year, sorry about that.
Hi all,
Here is the code.
Code:
repeat
	try
		get theFolders
	on error
		exit repeat
	end try
end repeat
get theFolders
set i to 0
set aRow to 0
set bRow to 0
set mySession to {}
	delay shortDelay
			end if
					end repeat
				end if
			end if
			try
						delay shortDelay
					end repeat
				end if
				delay shortDelay
				tell mlWindow
					delay shortDelay
					-- Maximize window
					try
						-- click "Start"
						tell aRow
						end tell
						-- click "End"
						tell bRow
							key down {shift}
							delay shortDelay
							key up {shift}
						end tell
					on error e number n
					end try
				end tell
				-- Press ⌥⌘B
				-- Press "Bounce"
						try
							tell bField
								delay shortDelay
							end tell
							delay shortDelay
							keystroke return
							end repeat
							end repeat
						end try
					end tell
				end tell
			end try
		end tell
	end tell
end repeat
			end repeat
		end tell
	end tell
end if
end cliClick
			try
			on error
				return ""
			end try
		end repeat
	end if
			try
			on error
				return ""
			end try
		end repeat
	end if
	return theText
end trimText
  #256
Old Yesterday, 02:21 AM
oudi oudi is offline
HI everybody
FIRST
A big thank you for all the contributions....
Really nice....
i 'm in the begin of my apllescript adventure.
and thank of you i understand more and more.
BUT
i try to make a script for select the menu by criteria in soundfiled recording.
it's ok BUT
the end of the script is very very slow juste to do 3 key code action....
i don't understand.
maybe you can help me.
here is the script
Code:
activate application "Pro Tools"
    tell application process "Pro Tools"
        set window_name to name of front window
        -- key code for copy paste
        key code 8 using {command down}
        key code 41
        key code 9 using {command down}
        -- click pop up button for track P1
        click pop up button 1 of group "P1 - Audio Track " of window window_name
        -- type e for select expand channels and by criteria
        -- PROBLEM THE SRCIPT  VERY VERY LONG TIME TO DO THE NEXT STEP
        key code 14
        key code 124
        key code 36
    end tell
end tell
Thanks in advance.
best
ps : sorry for my beautifull PERFECT english
  #257
Old Yesterday, 04:05 PM
Originally Posted by oudi View Post
HI everybody
Code:
        key code 14
        key code 124
        key code 36
    end tell
end tell
Thanks in advance.
best
Its the infamous 6 second delay that occurs when you click the pop up button via AppleScript, you should use the Command Line Utility cliclick to perform the click.
See post #226 for a solution. 😉
  #258
Old Today, 02:34 AM
Hi
thank for the Good reply
i've (...you) solve the problem
Code:
        keystroke "c" using command down
        keystroke "m"
        keystroke "v" using command down
        tell pop up button 1 of group "temoin - Audio Track " of window window_name
            my cliClick("rc:" & xPosition + (xSize div 2) & "," & yPosition + (ySize div 2))
            key code 14
            key code 124
            key code 36
        end tell
    end tell
end tell
on cliClick(coordinate)
    do shell script quoted form of cliclickCLIPath & " -r " & coordinate
 end cliClick
By the way how can we access to the Group id...
it search because UIElementInspector find it and it's workx with axshowmenu
but.....lose
here is my first failled script
Code:
        click pop up button 1 of group "a - zik (VZIK)" of window window_name--a - zik (VZIK) is the name of my group
    end tell
 end tell
the UIElementInspector result
<AXApplication: “Pro Tools”>
<AXWindow: “Edit: Copie de EDIT OPJ S1 EP44 TO EDIT JF - 12”>
<AXTable: “Group List”>
<AXRow>
<AXCell>
<AXButton: “a - zik (VZIK)”>
Attributes:
AXRowIndexRange: “pos=1 len=1”
AXIdentifier: “1164199792:ELEM:1:1”
AXEnabled: “1”
AXFrame: “x=22 y=513 w=383 h=11”
AXVisibleChildren: “(null)”
AXParent: “<AXCell>”
AXChildren: “(null)”
AXFocused: “1”
AXTitleUIElement: “(null)”
AXColumnIndexRange: “pos=1 len=1”
AXRole: “AXButton”
AXTopLevelUIElement: “(null)”
AXSelectedChildren: “(null)”
AXAuditIssues: “(null)”
AXHelp: “(null)”
AXTitle: “a - zik (VZIK)”
AXValue: “a - zik (VZIK)”
AXWindow: “(null)”
AXRoleDescription: “bouton”
AXSubrole: “(null)”
AXSize: “w=383 h=11”
AXPosition: “x=22 y=513”
Actions:
AXShowMenu - Afficher le menu
AXPress - appuyer
and for the pop menu of right click what is the way to select menu directly.
like hide for example on the right click of track.
Thank you .
best
  #259
Old Today, 05:15 PM
Have you read the entire thread?
I mean really, have you?
Pro Tools 12 Trim Automation bleu@cheerful.com Pro Tools 12 2 08-16-2015 05:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 02:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 09:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 01:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 07:55 PM
