Old 07-02-2014, 03:57 AM
Rockman413 Rockman413 is offline
Default would auto-link link other wrong files?
Hi I'm concerned that:
Pro tools would normally auto find and link files if the original files are moved... Thus would it link wrong files, for e.g.:
Original file name is percussion1.wav, and there's also another percussion1.wav in another folder(but length is not perfecty the same, let's say , only 1frame difference in length) , then I delete the real percussion1.wav and reopen my session, would pro tools link the wrong percussion1.wav in the other folder in this occasion and similar occasions?
How doses it work?
Thanks!
Old 07-02-2014, 01:56 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Default Re: would auto-link link other wrong files?
It also looks at file ID as well as duration. If you search manually you can "find links" or "find candidates" depending on where you click in the manual find and relink window. If you click on find links a dialog will pop up with check boxes for file ID, duration, and some other parameters for your search. You can also define directories when you search manually which will be retained until ProTools is shut down. Auto find will look in every connected drive which can take a long time or flat out stop your progress.
Also be aware relinking will not copy the file to the audio files folder, just point ProTools to the location.
I will choose,
Freewill
http://jimdiazaudio.com/
Pro Tools Hd Trial wrong link? rabben82 Pro Tools 11 6 06-06-2014 10:37 AM
PT HD CORE & HD ACCEL + SSL Delta Link + SSL Alpha Link Noizz focushocuspocus Pro Tools TDM Systems (Mac) 1 09-29-2012 09:12 PM
Pro Tools Playback Issues at 88.2 with Delta Link / Alpha Link - Any ideas? azirkin macOS 1 01-17-2012 02:30 AM
7.3 factory bundle link is wrong for PPC dkstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-18-2006 03:18 PM
Digital Audio Extraction Link. Is this a good link? GuitarEasley General Discussion 0 04-16-2002 10:26 PM
