Old 02-19-2014, 11:14 AM
jasonlane jasonlane is offline
Default 'Follow Main Pan' on effect sends?
Hey,
Ok, this has been bothering me for some time and I would like all your feedback!!
We all create a reverb (or other effect) on an aux track and then use a send on an audio track to add the reverb.
When creating the send should the FMP button be enabled to follow the pan of the main audio track?
If the main audio track is not panned it doesnt matter of course, but if it is or it will be then the FMP button should be pressed right.?
Thoughts please!!!!
Jason
Old 02-19-2014, 11:43 AM
Raoul23 Raoul23 is offline
Default Re: 'Follow Main Pan' on effect sends?
Yep it sure should be Jason
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 02-19-2014, 11:47 AM
mesaone mesaone is offline
It depends. If you're sending to a mono or mono-to-stereo effect, then it doesn't matter. But if you're sending to a stereo effect, then pan will affect the result. Compare how everything sounds. Also consider the end goal:
  • Sometimes you are using your reverb to emulate a space, in which case you want things to act like they would in a space - use FMP. Or maybe you want to get creative, and reverse the send pan from main pan.
  • Sometimes you have a reverb just to act as a bed behind the music, so you wouldn't necessarily FMP.
  • What about a ping pong delay? Well, pan doesn't much matter for a single instrument. But when using multiple instruments, maybe it does. Use your ears.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 02-19-2014, 12:09 PM
crizdee's Avatar
crizdee crizdee is offline
I also say yes so the stereo placement stays more defined.
as mentioned mono in stereo out effects it doesn't matter so have follow the main pan anyway.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Coalesce 'Follow Main Pan' ? FlorianE Pro Tools TDM Systems (Mac) 0 05-11-2012 02:09 PM
Feature request: Pre Fader Sends follow Main Faders PeterScherr Pro Tools 9 13 06-11-2011 08:59 PM
Sends default to follow main pan pref Not on stereo tracks? crizdee Pro Tools TDM Systems (Mac) 2 12-15-2010 09:18 PM
Follow Main Pan defeats Center percent in 5.1? Rich Breen Pro Tools TDM Systems (Mac) 2 09-26-2008 08:15 AM
sends follow mutes sla Pro Tools TDM Systems (Mac) 7 12-18-2003 02:21 PM
