Old 10-31-2013, 12:59 PM
Pat.m Pat.m is offline
Default Adding MIDI drums to acoustic drums - Velocity
Hey guys, so I know how to add MIDI notes to an acoustic drum track (the whole tab to transient copy paste approach), but:
A: Is there a tool for shadowing audio peaks with MIDI notes faster (the copy paste approach can be time consuming and annoying)?
B: Is there a way to adjust the MIDI "shadows" to be more dynamically responsive to the audio track?
Thanks in advance guys :)
Old 10-31-2013, 01:32 PM
Glenjb Glenjb is offline
Default Re: Adding MIDI drums to acoustic drums - Velocity
I dont know the answers to your questions but agree this method is time consuming- I hope someone comes along with some tips. Also people swear by the Slate Trigger plugin but I've never used it.
Old 11-01-2013, 12:51 PM
Slate Trigger and Drumagog work quite well and will follow/track dynamics pretty well. You might try running drum tracks thru Melodyne to create a midi file as that SHOULD also follow dynamics. I use Drumagog to augment or replace acoustic sounds, or I paste in samples I create from the kit on the tracks(created by advancing paste the end of the song, and having the drummer record single hits on each drum). I have also used those "homemade" samples in Drumagog, but it sounds better if I paste them in(takes longer, but sometimes its worth it). Pretty sure that Massey's DRT plugin also creates a midi track and that would probably be my first stop to check out for your purpose.
Old 11-01-2013, 05:04 PM
Shan's Avatar
Shan Shan is offline
Massey DRT.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-01-2013, 05:46 PM
mesaone mesaone is offline
Originally Posted by Shan View Post
Will the audiosuite version work with PT11?
Old 11-01-2013, 09:40 PM
Shan's Avatar
PT 10 and under only, until they get AAX out the door.
Shane
Best PT AIR VI to load custom multi-velocity samples for drums? Badelement1 Virtual Instruments 2 11-04-2013 01:56 PM
adding drums on an existing midi track aehn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2010 11:20 AM
OT. acoustic or electronic drums? ESR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-11-2004 12:58 AM
Best way to record Acoustic drums.. TheLP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 03-17-2004 07:07 AM
Miking Acoustic Drums with the 001 BigALW1414 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 12-12-2001 03:38 PM
