Old 08-12-2013, 11:37 AM
nikydvt nikydvt is offline
Default Pro Tools 11 and Max 6
I have recently upgraded to ProTools 11 and unluckily I noticed that Max 6 has disappeared from the list of plug-in available instrument, otherwise than ProTools 10. I also wrote to ProTools for explanations but they answered “Max doesn’t function in ProTools” (Lapalisse-like answer !!!). Could you tell me if in the future Max will function again with ProTools (DigiRewire is still present in it). And in the meanwhile can I use Max with ProTools throught hardware (I use a Fireface UCX multichannel interface)wiring for instance: ProTools MidiOut –> to MidiIn Max–> Audio–>AudioIn ProTools; Shall I not insert in this way an excessive delay ? Thanks niky
Old 08-12-2013, 03:32 PM
profdraper profdraper is offline
Default Re: Pro Tools 11 and Max 6
Not sure if this helps, but I use Max 6.1 inside Ableton Live 9 (64bit) as a Rewire application to PT11. Works well.
