Old 03-13-2013, 04:40 AM
alex s alex s is offline
Default Elastic Audio - Sounds Dreadful after committing
I'm running pro tools 10.3.3 on an 2011 i7 MBP running OSX 10.7.5
I'm transferring a bunch of interview from cassette for de-noising etc.
On some of the cassettes, during the interview the batteries ran out on the cassette machine so the tape slowed down / talking speeds up as does the pitch.
I'm using Elastic audio's Vari speed algorithm to sort this problem out and it sounds fine on playback. But when I commit the audio file either by consolidating or removing elastic audio and committing the audio sounds awful, as in completely different from the adjusted original.
I've also tried bouncing the playback to another track but the same problem persists.
Is anyone else having this problem ?
Thanks,
Alex
Old 03-13-2013, 04:55 AM
ondruspat ondruspat is offline
Default Re: Elastic Audio - Sounds Dreadful after committing
If it sounds fine on playback but is screwy only when you commit try just routing the output of that channel to a new one within the session and record a new track of "fixed" audio. It may not get to the heart of your problem but it will get you results quickly.
"Sometimes having limits keeps you sane"- Albee1952
Old 03-13-2013, 05:07 AM
Hi Onduspat,
Thanks for your reply.
Unfortunately that's what I've tried too. It's what i meant by "bouncing the playback to another track".
i'd previously set up 10 or so of these "bounce to tracks" at the same time and just set it recording without listening, then heard the same problem as the consolidated tracks on playback.
I'm now in the process of bouncing each track individually while listening. Interestingly / V.annoyingly I'm experiencing it sounding ok for a while then it's as if the processing degrades all of a sudden. I then have to stop and drop in at the point where it started to sound bad.
Unbelievably annoying !
Old 03-13-2013, 05:17 AM
I've repeated this 3 times using different material.
When bouncing to another track the processing degrades considerably at about 6min 40 sec EVERY TIME.
Old 03-13-2013, 09:28 AM
Kasper Kasper is offline
Are you using Real Time or Rendered audio?
Try Rendered only.
Any difference?
kasper
Old 03-13-2013, 09:40 AM
Chief Technician's Avatar
Lightbulb Re: Elastic Audio - Sounds Dreadful after committing
Are there any video files in this session?
Old 03-13-2013, 10:01 AM
Hi kasper,
I've tried bounce to track, consolidating and committing/rendering by removing elastic audio from the track - all with the same result.
Did you mean something else ?
and no, no video Chief Tech.
Thanks,
Al
Old 03-13-2013, 01:15 PM
In the track, where you pick the Elastic Audio algorithm - you can have real-time or rendered only.
Also, have you tried x-form, rendered only?
Set to highest quality.
kasper
Old 03-13-2013, 01:34 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Not shure this applies to your issue but 10.3.4 has a fix for Elastic Audio.
http://akmedia.digidesign.com/suppor..._Win_78870.pdf
Rhythmic algorithm accuracy improved when extreme compression/expansion settings exist on an Elastic Audio track
(PTSW-177009)
Old 10-10-2013, 02:39 PM
DDBass DDBass is offline
Alex,
I run into this issue as well and was wondering if you ever got the issue resolved. There are lots of topics about this issue but no one ever posts how and if they got the issue resolved.
Thx,
Dave
Macbook Pro
OS X 10.8
2.8 GHz Intel Core 2 Duo
4GB RAM
Protools 10.3
Digi 003 Rack + Factory
MOTU 828 MkII
Glyph GT050Q
Novation SLK MkII
Have to manually clean up rendered files after committing elastic audio processing jdholman1 Pro Tools 9 1 05-30-2011 01:57 PM
Elastic Audio not committing to disk properly mixboy bob Pro Tools TDM Systems (Mac) 4 05-27-2009 01:32 PM
committing elastic audio in 7.4 is it fixed yet 2fly Pro Tools TDM Systems (Mac) 9 01-15-2008 06:08 PM
Committing Rewire tracks to audio files. logic7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-26-2006 10:30 AM
Committing Amplitube to audio? jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-17-2006 02:30 PM
