Old 01-24-2011, 10:00 PM
Chronobot Chronobot is offline
Default Sound coming from only right or left side?
Alright, well here is my issue. Whenever I plug in my speakers (Studiophile AV30's; not the greatest I know, but need to suffice for now til i get my krk 8's..), I get sound only coming out of one side.. I understand they're not 1/8th Aux. input and not 1/4" TRS for each monitor.. but a friend of mine has the Mbox 2 pro which a 1/4" TRS to 1/8th seems to do the job. is there a way to get playback sound from both?
Which is also the same scenario when I plug my headphones in to one of the headphone inputs.. its either right or left side the sound only comes out, depending on which side its placed in. But Once i get my headphones that are actually TRS, what are the odds of the exact same thing happening? since there is 2 headphone outputs..
It may be my 1/8" male to 1/4" Female adapter, but I have yet to switch them out to find out.
Any suggestions? Thanks!
Old 01-25-2011, 10:46 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Sound coming from only right or left side?
Is your adapter two or three wire? Does it have a ring, tip and sleeve connections?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-25-2011, 10:50 AM
What I would ask as well. The adapter(s) is the first thing to check. Using real studio monitors(even inexpensive ones) will be a step up. There are some decent choices for under $400, including Behringer 2030A and KRK Rokit6 G2's.
Old 01-25-2011, 11:54 AM
Bill Denton Bill Denton is offline
You didn't mention what interface you're using, but assuming it's something like one of the MBox units, this is what you would need:
http://accessories.musiciansfriend.c...ble?sku=330481
Whether you use an unbalanced (TS) cable like this one, or a balanced (TRS) cable is immaterial. The Studiophile AV30's don't have balanced inputs.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 01-25-2011, 03:39 PM
I think he is using an adapter to feed his speakers from the headphone out.
Tough to say since the post is not clear but he is hearing only one side of his headphones when using that same adapter. So it is important to know how his adapter is wired.
We are talking about the output of his hardware and how it is connected to the speakers. He is using an adapter from 1/8" to 1/4". If it is two wire, that's why he hears only from one side.
Yes, he needs a 1/8" stereo to two 1/4" two wire. A headphone output is not balanced.
How his speakers are wired was not part of the discussion.
I don't know why he just doesn't use the main monitor outputs for his speakers. Better impedance matching to a powered speaker.
Park
Old 01-28-2011, 03:43 PM
Hey guys, sorry for the late reply. I made the post super quick(PC's psu died on me, just got new one in mail today) before I went to work.
anyhow.. i'm using the mbox pro 3. Being the burnout I am, i totally forgot about the stereo > two wire trs cable. hahaha.
Makes sense. Also this is what I was trying to get at:http://www.amazon.com/Hosa-GPM-103-3.../dp/B000068O3T
Typical 2 ring'd adapter. I did find it to be a cause of some headphone issues, of which are irrelevant to what I was asking.
Thanks a ton though dudes! Appreciate the spawn of help I got. I shall be continuously lurking the forums from now on
expect many questions, hahaha.
Hails!
Sound in left side of Headphone jasont Windows 4 12-24-2013 12:02 PM
Sound only coming out of left speaker chrisshack89 Windows 5 05-29-2013 01:35 AM
Only getting sound from the left side from digi rack002/standalone mode s1rdelek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-27-2011 12:55 PM
Sound only coming from one side? ryan482 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-07-2010 02:03 AM
I only get sound out of left side of headphones msgood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2009 09:16 AM
