Old 02-17-2010, 01:46 PM
smpkeys smpkeys is offline
Default Can I move regions and have the underlying playlists move also?
I have a song that the client wanted to add an additional 16 bars of an interlude to the front of the song. The quickest way on the spot was to add it to the end , with the intention of moving it to the front later. I can do this in shuffle mode, but is there a way to have the playlisted tracks underneath move also (as to stay with the tracks on top)?
Thanks DUCers!
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 02-17-2010, 01:48 PM
Sean Russell Sean Russell is offline
Default Re: Can I move regions and have the underlying playlists move also?
If you open all the playlist lanes and edit them together, you *should* be able to move them. Just save-as and watch out - sometimes editing with all the lanes open can make PT fail.
Good luck.
... but does it help the chorus?
Old 02-17-2010, 04:06 PM
Thanks Shawn, I'll give that a try
Old 02-18-2010, 07:31 AM
JMDNYC JMDNYC is offline
I think Insert Time should do it, under "Event / Time Operations..."
Old 02-18-2010, 08:30 AM
Drew Mazurek's Avatar
It doesn't unless all playlists are "open".
www.drewmazurek.com
Move the red diamond in the tempo bar in the edit window, only some tracks move kingheartless macOS 2 02-21-2013 04:20 PM
regions won't move! bontay Pro Tools TDM Systems (Mac) 5 01-25-2011 09:55 PM
How to move several regions at once DonaldM Tips & Tricks 12 07-22-2009 08:54 AM
Move markers with all the regions Riccardo Corbari Tips & Tricks 2 03-17-2008 10:59 AM
simultaneously move takes in playlists? soundguy_2000 Pro Tools TDM Systems (Mac) 7 02-23-2008 12:53 AM
