Old 04-15-2002, 08:58 AM
pnoise pnoise is offline
Default How to wire up an LA-3A?
I know this isn't exactly a Digi topic...but I figured some of you might be using these (or maybe had in the past). I just assumed that you all would be a better resource than the PTLE or Genereal forums.
I have an Urei/Teletronix LA-3A Leveling Amplifier sitting around the studio that I would like to make use of. However, I am not sure of how to connect the wires. The back does not have input or output connectors, but wrap-around/screw-in contacts. Starting from the top and going down here is how they are labeled. (o = screw contact point)
o +/-
IN
o Com.
o Chassis
o Stereo
o Com.
OUT
o +/-
I know this is basic wiring and I could probably pull a trial and error test, but I don't want to mess this unit up, as it is my boss's, not mine.
In addition, there are two other screw/type adjustments on the back:
1) Stereo adjustment - the label mentions turning the screw colockwise for "MONO."
2) HF Contour - turn screw clockwise for "FLAT"
What would be the optimal settings on these?
Thanks for any help you can give.
Steve
Stephen Shirk
www.stephenshirk.com
www.pinknoise.com
Old 04-15-2002, 12:10 PM
stoneinapond stoneinapond is offline
Default Re: How to wire up an LA-3A?
Can't help you personally, but if you head over to Recording.org and ask on the producers, engineers, hardware forum, I'm sure you'll get a quick reply.
Hope this helps,
Yorik
Old 04-16-2002, 01:07 AM
dave-G dave-G is offline
Connecting this thing is relatively simple -- what you're looking at is called a barrier strip. You can simply attach bare wires to it, but you'll be a little slicker if you crimp or solder some decent spades on to the ends of your wires. You should be able to get spade connectors (U-shaped prongs that go under the screws) at Radio Shack, or at your local electronics supply.
+ gets the hot wire (most likely pin 2 if the other end is to be an XLR)
C gets the negative side to pin 3 on your XLR
Com is ground, shared--to pin 1 of your XLR
stereo (if memory serves) allows you to put a jumper from one unit to another to sum their voltage control (by the amount set on the trim-screw you noted) for stereo tracking.
These and the HF settings will likely make themselves evident once you've got this thing set-up so you can hear it. If you have any other questions, you might want to ask your local service-tech, or maybe post something to John Klett's forum on PSW.
-dave-G
DAVE GREENBERG
SONOPOD MASTERING
re re wire 2224 Pro Tools 9 10 07-25-2012 04:28 PM
How to wire this!? im new at this steveguitargt Pro Tools M-Powered (Win) 3 07-20-2007 06:26 AM
re-wire Krav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-03-2007 09:21 AM
How do you wire TRS -> XLR??? Camilo Orozco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-17-2004 03:30 PM
Wire this... spicyitaliano Pro Tools TDM Systems (Mac) 4 01-27-2003 11:55 AM
