Old 03-21-2008, 04:51 PM
cclarkaudio cclarkaudio is offline
Default Error 9093- Need some help...
I just started using PT on my laptop with an Mbox 2 as hardware. I am getting the 9093 error code when recording. It states
"The operating system held off interrupts for too long. If this occurs often, try increasing the H/W buffer size in playback engine dialogue" (9093)
I will start recording a session then about ten min or so into the recording the error message appears and stops the recording.
I thought it was a CPU usage issue, or possibly a Vista issue.
Can anyone shed some light on what this means and how I can fix it???
Old 03-21-2008, 05:25 PM
chazzo03 chazzo03 is offline
Default Re: Error 9093- Need some help...
Do you have a external firewire drive with oxford 911 chipset? If not go and get one. Thi is the one i got.
http://eshop.macsales.com/item/Other.../ME2FW7160GBJ/
Also did you do the vista optimizations?
http://www.digidesign.com/index.cfm?...4&itemid=28469
But most importantly you have to make sure your pc is compatible.
http://www.digidesign.com/index.cfm?...0&itemid=29586
http://www.digidesign.com/index.cfm?...4&itemid=28565
Old 03-21-2008, 06:21 PM
My mbox runs on USB so firewire dosnt apply.
Also as far as the vista optimizations, I didnt know there were any so ill try those.
Old 03-21-2008, 07:02 PM
The Weed's Avatar
The Weed The Weed is offline
He's talking about an external firewire drive for your recording sessions, NOT the M Box connection.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
DAE ERROR 9093 Babu1210 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2007 02:16 PM
ERROR -9093 Soth41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-11-2003 12:19 PM
error 9093 FernandoJMercado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-03-2003 08:03 PM
1 Cure for error 6085 and error 9093!!!!!!!!! CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2002 08:30 AM
-9093 error, please!!!! EDurney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-18-2002 01:28 AM
