Trim Coalesce - how to do it from the surface
I'm trying to figure out how to coalesce trim automation from the surface without having to go to the menu on the screen. It's great that the 'trim' light blinks to show that there is trim automation somewhere - now I'm hoping that a combination of modifier keys and a press of the global trim buttion will do coalesce said automation! I've had a good look around, and can't find any mention of this anywhere - can anyone shed any light for me? Many thanks, Mat
ICON D-Command, PT 7.2cs2 HD3, G5 PowerPC Dual 2GHz. A bunch of plugins! |
Re: Trim Coalesce - how to do it from the surface
yup: its under action (4nd page) Colesc TrmAtm... However, i've noticed on a few occasions where the button won't be lit up even though i have trim automation begging to be coalesced and the solution i've found is to hold down option and hit the button...
Thanks mate - hmmmm, it's not very easy to get to on the fly is it! I've tried 'option' and the button, but that puts all channels into trim mode... unless I'm missing something!
Mat
no, but you can add it to your user bank if that makes life easier... what i was saying is this: there appears to be a bug where sometimes, even though i have non-coalesced trim automation the ColescTrmAtm button isn't armed or lit... and the way that i've been able to get it to work is by holding option and hitting ColescTrmAtm... that doesn't change the automation status though on any of the faders...
To trim coalesce a track, you need to select the track with the Sel button. Then, the button will light up under action.
Gil
Gil Gowing Principal Digimidi Technical Services |
aha! cool... was wondering what was going on.... and option (obviously) will coalesce all... lovely...
It took me a while to figure out that the 'trim coalesce' function only works if you have the tracks selected, so that makes sense about the 'action' button functionality... but it's a shame there isn't a quick and easy way of hitting the 'trim' button with some modifier keys. A product recquest perhaps?
Hi, I'm operating in 'coalesce manually' mode - I don't want ProTools coalescing for me!
It's a function on the big console I'm used to using, and I use it all the time. Basically, any fader that is in trim mode will coalesce when you hit the one 'trim coalesce' button, or if you hold down the 'all' button when you press the trim coalesce button it, not suprisingly, coalesces everything.... It would be great to have that functionality on the D-Command. Would it be possible to impliment a modifyer button plus 'trim' button in the 'auto mode' section to provide this functionality? Any thoughts Digi? Mat
PT9+003: Turn Trim mode on/off on 003 surface? | reichman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-30-2010 12:44 PM |
Trim mode from 002 control surface? | SirLexelot | Pro Tools 9 | 1 | 11-16-2010 12:05 AM |
Volume Trim and Coalesce | erant1 | Pro Tools TDM Systems (Mac) | 2 | 07-05-2008 07:41 AM |
Can't write trim automation from control surface | crizdee | Pro Tools TDM Systems (Mac) | 1 | 10-26-2006 10:28 PM |
How do I coalesce volume automation? | sugarplum | Pro Tools TDM Systems (Mac) | 11 | 07-20-2002 08:16 AM |
