Old 03-09-2005, 07:56 PM
Greg M Greg M is offline
Default 002rack left side 3db louder than right
Has anyone else got a 002rack where the monitor outs volume is not balanced. The left side of mine is about 3db louder than the right side. I've measured it with a sound level meter on 3 sets of monitors. It's not insurmountable since I balance it with the monitor volume trim, but a bit disapointing.
Any way to fix this?
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 .
Old 03-09-2005, 08:07 PM
Chris Cavell Chris Cavell is offline
Default Re: 002rack left side 3db louder than right
potential factors you could look at:
faulty cable
room acoustics (particularly if you're setup is near/in a corner)
faulty amp
non-matched monitors
Cavell Studios
Old 03-09-2005, 08:11 PM
RolandK RolandK is offline
I had this problem once last year, turns out it was a power amp with individual left/right level controls that were out of alignment.
Old 03-10-2005, 08:08 AM
oldhousedave oldhousedave is offline
Yea, mine does it too, except it's the right is louder than the left, I think? I'm not at the studio right now but I never give it much thought because I don't mix in PT. I just use it for editing so when I'm thru, I dump the tracks onto a hard drive which goes in my HD Recorder so I can then mix the right way, ANALOG!!!
I bring the 002R into two channels strips of my analog console (just for control room and headphone monitoring) via their line I/P's and just trim the inputs to balance. It's not caused by any of what was suggested here, I see it on the meters in the console as well as hear it. There is probably an adjustment pot or should be somewhere in the 002R. I may check it out, I don't think it will screw with my warranty because I've already opened it up to install the P/S harness fix. If I remember correctly I think I am comming out of the main O/P on the 002R. I haven't tried any of the other O/P's to see how they balance out?
You may want to take advantage of your warranty and send it back, if it's still covered. But first I would plug it direct into something with good meters and run a test tone thru two channels of it set at unity gain, first without a master fader and then with a master fader just to make sure it's not what the others suggested, or something else.
Good luck!
David
RIGHT louder than LEFT output!!!HELP!! [SOLVED] MallahStudio macOS 5 11-26-2013 06:17 PM
Mbox2 Mini right side 2x louder than left? maudotron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-23-2013 04:29 PM
One side Louder than other - Mix Buss? JazzyJ macOS 0 09-04-2012 09:31 AM
Left channel output louder in Mbox 1, please help. pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-14-2008 10:40 AM
001 Out levels Left side hot? ajazzie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2003 10:12 PM
