Old 01-02-2005, 01:29 AM
sdelsolray sdelsolray is offline
Default Coreaudio 6.7 messed things up
This is a Digi001 question. I realize the Digi001 isn't supported anymore, but nonetheless, here's the quesion/problem:
I installed coreaudio 6.5. PTLE 6.4 runs fine (OS 10.3.6). But no other sound application works through the Digi001 card. If I select the Digi001 in the Sound SYstem Preference window, no other application (except PTLE) will generate a sound (iTunes, Amadeaus II, Quicktime, etc.).
I've updated to Coreaudio 6.7 and OS 10.3.7, same thing. LAst time it worked was before the Coreaudio 6.5 "upgrade". Coreaudio 6.4.2 I believe with OS 10.3.4.
Anybody with a Digi001 out there have this problem? Am I going to have to downgrade my OS and Coreaudio?
Old 01-02-2005, 11:41 AM
Default Re: Coreaudio 6.7 messed things up
bump
Old 01-02-2005, 12:55 PM
Bee-man Bee-man is offline
I took a chance and downloaded the latest coreaudio along with updating my OS to X.3.7 and i'm running a 001.
Everything is working as it should.....dare i say even better.....
I know this doesn't help you any....Perhaps a bad DL.......trash and try again.
One more thing....did you repair permissions.Apple suggests doing that after every update.
Good luck
MDD DP 867 512mb OS X.3.7
001 w/6.4
Old 01-03-2005, 06:44 PM
OliJ OliJ is offline
Just wondering exactly which core audio that was, 6.5 or 6.7? I'm assuming you're still using 6.4 software or did you update this to 6.7 as well? Love to know!
HD1 2.26 8 core Nehalem PT9.05 OSX10.6.8
Old 01-03-2005, 10:35 PM
[/QUOTE]
Coreaudio 6.7 is "the latest",........and FYI the 001 software developement was ended with the release of vers. 6.4 (i'm still using this release)
There will be no more updates that officially support the 001.That's not to say they won't work,just don't expect them to.
All this brings up another worry of mine.At some point i'd imagine that LE vers. 6.4 would be left behind with the advancement of the OS X.?.?.........or am i wrong.........
001 w/6.4
Old 01-04-2005, 12:04 AM
Thanks Bee-Man, I was sort of hoping you were going to tell me that the 001 would in fact run with 6.7 -I know it was a vain hope, but some one is bound to try ....I myself don't want the honour of being the first however!
I wouldn't worry too much about 6.4 being left behind by Mac OS advancements too much. I believe it's very unlikely that version 7 protools will actually support the Mac platform. So you're not going to miss much.
Old 01-05-2005, 09:29 PM
Good luck
What's a "DL"? I tried the repair permissions thing. Didn't help a bit. ANy thoughts?
Have I messed up? nickmadsen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-26-2011 02:32 AM
EQ III is messed up wigglybeef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-25-2009 03:50 PM
Is my Mic messed up or what ??? Talent4God Post - Surround - Video 27 10-01-2006 08:03 PM
iMac G5 !!!good things and bad things!!! Jervy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-28-2005 02:36 AM
This DUC is messed!!! Michael Cottrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-04-2002 11:42 AM
