Old 11-14-2015, 11:54 AM
TheDavidLim TheDavidLim is offline
Default Sending Cues to Outputs on SC48
I'm sure it's obvious, or maybe not, but I'm trying to set up my SC48 so when I solo a channel it sends to an output (for SMAART). I want my headphones to stay connected too, or I'd just use that jack. I've patched the Monitor outputs to physical outputs but for some reason nothing is sending. What do I need to do?
Thanks!
Old 11-14-2015, 12:46 PM
Brent Lind Brent Lind is offline
Default Re: Sending Cues to Outputs on SC48
Do you have the monitor output master at 0dB?
Old 11-14-2015, 03:02 PM
Ah. That did it, didn't realize that there was an internal control, I thought it was just the encoder on the Monitoring section.
So I can send EITHER the L or R to my mono output, how would send both LR? I might have missed this too, but I didn't see a way to matrix the Monitor sends, to do something like that.
Thanks for the help!
Old 11-15-2015, 02:41 PM
You can matrix the monitor sends if you use an AES or S/PDIF loopback, then just use the return channel as a "user defined" input at the matrix.
Old 11-16-2015, 05:57 PM
That makes sense, I'll use that. Thank you!
Sending Click track to just one set of outputs Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-06-2009 05:37 AM
Incorrect Outputs sending my loopy! can anyone help?! RJW1982 Pro Tools TDM Systems (Mac) 6 09-24-2008 11:04 AM
Multiple cues? The_Shoe VENUE Live Sound Systems 14 08-28-2008 08:59 AM
Digi 003 is sending stereo ADAT outputs as mono summed wallysound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-04-2008 02:10 PM
Sending outputs to two different places Project 8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-24-2007 11:48 AM
