Sending Click track to just one set of outputs
I was doing a test drum recording with a drummer, and wanted to give him a click track,
I had the second set of headphones on and the monitors where also on, is it possible to send the click track to just headphone output 1, is it as simple as selecting output 1 (or whatever the correct headphone output would be) on the fader ? |
Re: Sending Click track to just one set of outputs
Both headphones outs only mirror analog 1-2, I think. (I didn't look, on a 003, right?)
Send analog 3-4 (or just 3) outputs to a headphone amp or small mixer is the only way I can think of...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
On family fued, we would, GOOD ANSWER-GOOD ANSWER
open the output tab on the click track and hold down control+option and select an additional anaolg out that you're using elsewhere- this will add it to 1 & 2 (I'm assuming you're using that as your main source?)
I use a Presonus (6 channel model.... can't remember the model) which has stereo A and B inputs. Since a stereo mix in the headphones seems to throw many players, I sum to mono, the L/R signal from Analog 1 & 2 goes to A and B now gives me 2 more signal options- patch the additional output from the click to one of the B inputs and pan everyone elses mix to 100% A (or else they'll hear the click) or you can send the additional analog output as an insert into the headphone (if yours allows for this)- My presonius does this, but I ran out patchbay spots so I can't access the back of it ... though I may revisit that someday If you have trouble getting the additional output dup the click and assign the dup'd track to a different output hope this makes sense
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
great input guys, I'll play with it this weekend.
thank you |
sending a click to the headphones only | musimedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-08-2009 01:25 AM |
Incorrect Outputs sending my loopy! can anyone help?! | RJW1982 | Pro Tools TDM Systems (Mac) | 6 | 09-24-2008 11:04 AM |
Digi 003 is sending stereo ADAT outputs as mono summed | wallysound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-04-2008 02:10 PM |
Sending outputs to two different places | Project 8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-24-2007 11:48 AM |
