Old 04-14-2002, 01:44 PM
beggehorn beggehorn is offline
Default Re: Where would you rate plug-in reverbs
I had a chance to sit down last night and A/B some different plugin verbs with an H3000. The plugs I compared were D-Verb, Waves Ren Reverb, True Verb and one other I can't recall. D-Verb (the only one I own personally of the above list) has never made me happy. Ever notice how it makes things sound small and thin? Awful and easily the worst by comparison. By far the winning plug was the Waves Ren Reverberator. Very smooth and very cool parameters: EQ and damping, early reflection control with ability to have a negative time value which puts the reverberation before the "not-so-early" reflections. Most of all the sound was rich and full, made the source sound bigger and fuller (as it should). I had a hard time choosing between the Eventide box and the Waves plug. Without really using them for a while it would be hard to choose a favorite between the two. Of course the H3000 has a stack of other algorithms to boot. Its cool to have plugs for session recall and multiple instances but outboard won't require upgrades to be compatible with whatever version of DAW you might be using down the line! Tough call. . .
Windows 10 Pro x64
Avid HDX running PT Ultimate 2020.x
ASUS WS x299 SAGE 10g
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
Old 04-14-2002, 03:35 PM
Hardnox Hardnox is offline
If you buy another Mix Farm, all you plugs will benefit from the extra DSP, not just Reverb. What about Reverb One?
www.hardnoxproductions.com
Old 04-14-2002, 03:58 PM
Peter Duemmler Peter Duemmler is offline
I just love D-Verb for the nonlinear patch (for drums mainly).
I often don´t turn on my R880 because D-Verb is much easier to use.
Peter
http://www.merlinsound.de
Old 04-14-2002, 05:11 PM
emilano emilano is offline
I also like the D-verb for specific uses. Its hall setting sounds very nice on acoustic guitar with a little tweaking.
Old 04-14-2002, 05:38 PM
gavinchan gavinchan is offline
A little off the topic, but I just wanted to add how happy I am with the KORG Oasys Reverbs. When I bought it, I was thinking 'yeah, it will be great for all my synth sounds, quality of effects might be questionable.' Now I use it all the time. The other verbs I have are D-Verb/ Waves RVerb and TrueVerb, and I don't hardly touch them anymore. Korg Oasys sooooo rocks. [img]images/icons/smile.gif[/img]
Old 04-14-2002, 06:36 PM
musicsmith musicsmith is offline
Just sending in my vote for the korg oasys too.
Best 300 bucks I ever spent
Old 04-14-2002, 11:17 PM
tzujan tzujan is offline
Hardnox,
I have not tried Reverb One. I have heard great things about it. How does it compare to others?
I am toiling with the extra farm. I have come to a realization: the closer the gear is to being an instrument (literally and figuratively) the longer its life is in my studio. Is still have a CP-70, and 12 string guitar and a sm 57 all purchased when I was in high school. I can't tell you how many recording formats I have gone through over the years. It is insane. When I weigh the external chassis and the farm card I'm not too far from upgrading to HD.
Old 04-15-2002, 12:11 AM
Kedron Porter Kedron Porter is offline
Nobody has mentioned Real Verb or Real Verb 5.1. Alot of options and a nice clean sound. Have D-verb but not too impressed. It lacks great depth and very limited options compared to Real Verb.
Famous Quotes: You will never need another operating system past windows '95
-Bill Gates
Old 04-15-2002, 12:21 AM
Default Where would you rate plug-in reverbs
I have been considering buying an external reverb in lieu of using plug ins. Reverbs and delays take up so much dsp. Buying another farm card would also mean buying an expansion chassis and I would still be left with an ok sounding verb. My thought is for less money, which is key, I could buy a nice external verb and an external delay with a better sound plus the benefit of free dsp. I would like to step up in a verb so my question is where do the plug in verbs rate with the external verbs. Is the Lexiverb comparable in sound to the PCM91, MPX 500 or the MPX 110? I am not a fan of the Mega Verb - where would it rate among its hardware brethren? How about other plug ins compared to the Lexicon line?
Old 04-15-2002, 06:42 AM
Skwaidu Skwaidu is offline
I haven't tried Rev One(Should try that!) or Realverb but in my opinion plug verbs aren't that good. Still I use them a lot, convenience and recallability being the major issues.
D-Verb:Mostly crap. Ok on some effect 'verbs, as you can put it as an RTAS insert without killing your CPU.
TC Mega: Surprisingly crap. Good programmability though. Haven't tried M-One, maybe comparable to that?
Lexiverb: Good for some uses, not much compared with PCM91.
Trueverb: Sometimes ok, I use it a lot. Many times as an early reflection generator, but lately have been bored with the same old sound, which isn't that classy either.
RenVerb: Haven't used it too much but seems interesting. Although I know that you can easily get ****** sounds with it, too.
Only my (non- well thought)opinions. Usually if I'm doing really serious mixing I tend to take my main 'verbs from boxes like TC MX000(X=3,5,6) and PCM91. Hope to get access to a 960L someday.
Skwaidu
Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, OSX Mojave, PT Ultimate 2020.5, HDX2, HD I/O 16x16 and ICON D-Command ES.
auto matching pull factors + frame rate + timecode rate Dingo90 Post - Surround - Video 1 10-17-2009 04:16 AM
Plugin Reverbs vs Outboard Reverbs midnightsun Pro Tools TDM Systems (Mac) 52 09-07-2009 02:46 PM
IR Reverbs Larryboy Pro Tools TDM Systems (Mac) 0 04-04-2005 05:37 PM
Plug ins vs. Hardware Reverbs runner Tips & Tricks 17 03-18-2005 05:45 PM
Favorite Plug-in Reverbs for Horns bruceup Pro Tools TDM Systems (Mac) 0 08-08-2003 11:29 AM
