Old 04-28-2001, 11:56 AM
wellenreiter wellenreiter is offline
Default samplerate conversion
Hi, I'm looking for a fast way to do a sample rate conversion on many wav's.
Is there a way to use the samplerate conversion (and to alter the settings) of PTF from the command line (DOS-Prompt in Windows?)
If not I'd be very happy to hear of other programs which will offer me this feature (in a top quality conversion - time's not that important).
Thanks for your ideas
Keep on rockin'
Peter
Old 04-30-2001, 05:47 AM
sweave sweave is offline
Default Re: samplerate conversion
PTF will convert audio files when you import them, though the sample rate you work with may be dictated by your soundcard - e.g. I have a sblive! so have to work at 48 not 44.1. consequently all imported wavs are converted to this.
PTF will also convert via bounce to disk with conversion. This is where I can convert the whole track to 44.1 for Cd burning. You have options re conversion quality at this point, though "tweak head" may take some time.
Presumeably you could import 8 wavs to different tracks and then bounce one at a time and convert?
Cheers,
Sweave
[This message has been edited by sweave (edited April 30, 2001).]
Old 04-30-2001, 01:02 PM
Hi Sweave,
thank you very much for your response
I'll try a memory upgrade (hoping PTF will run faster then). I've also found SOX (for DOS and Linux) which does seem to be good. I'll make some tests to see if PTF or SOX is better (and/or faster).
Regards
Peter
HTML code is On
Locking samplerate Picophone Eleven Rack 1 01-27-2014 02:00 PM
strange samplerate conversion problem floriand D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-29-2007 07:28 AM
Samplerate conversion within PT? davey boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-10-2007 08:44 AM
MBOX 2 PRO could not set samplerate Eruk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2007 04:02 AM
samplerate conversion help candystation Pro Tools TDM Systems (Mac) 2 06-12-2003 05:22 AM
