Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 07-27-2020, 04:52 PM
Thenewexhibit Thenewexhibit is offline
Default MIDI editing question.
Hello! I had a question about MIDI editing. I am basically un-quantizing the midi notes to have a little more of a human feel, and as a result, there are gaps in the midi. I know I can go to note duration to fill these gaps, and this works really great if all the notes are the same note, but the problem is that the last notes of the midi before a new note change get extended past the range and overlaps into the start of the note change.
What I'm basically asking is is there a command that fills the gaps in midi until the start of the next note regardless of pitch?
Old 07-28-2020, 06:03 AM
daeron80 daeron80 is offline
Default Re: MIDI editing question.
It might be more efficient in that case to trim the notes rather than moving them.
David J. Finnamore
Nyquist was right.
PT 2020.5 Ultimate | Omni | macOS Mojave
PT 2020.6 | Saffire Pro 40 | Win10
Old 07-31-2020, 09:36 AM
RTGraham RTGraham is offline
If I'm correctly understanding your question, then you can do the following:
In the track's real-time MIDI properties (which you can get to by control-clicking the track and selecting it from the context menu, or by exposing it in the track header - but the track header version doesn't always offer as many of the parameters), enable the "Duration" option, and set its mode to "legato/gap." You can then specify how much time (in beats / ticks) should be in between the end of one note and the beginning of the next.
See if that does what you're trying to do.
MIDI Editing Question. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-07-2010 08:03 PM
MIDI editing question ivet MIDI 1 09-03-2008 09:55 PM
Probably a stupid MIDI editing question... nickdahl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2008 10:54 PM
MIDI Editing Question - Converting BPM shendrie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-16-2003 10:04 PM
MIDI Editing Question markmcc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2001 12:30 AM
