Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 07-12-2020, 04:59 PM
Thenewexhibit Thenewexhibit is offline
Default Install Pro Tools 2020 beside Pro Tools 12?
I'm on a Mac, and I'm pretty sure this is feasible, but is this safe to do, by changing the name of my current version of Pro Tools 12 to "Pro Tools 12", I can then install Pro Tools 2020 to run it in parallel (not at the same time obviously) and test it on my system to see how it works?
If so, anything to worry about when doing this? Do you guys do this with new versions?
Old 07-12-2020, 05:02 PM
Default Re: Install Pro Tools 2020 beside Pro Tools 12?
Yes as long as your system is compatible with 2020. Your plugins and the pref files are shared so that could cause issues. Try it.
Old 07-12-2020, 05:29 PM
JFreak's Avatar
JFreak JFreak is offline
Not supported anyway. Compatibility info here.
Basically you need 10.13.6 or later for 2020.x and maximum of 10.13.2 for 12.8.3 -- but with that said, I'm pretty sure 12.8.3 works just well on 10.13.6, just not tested by Avid.
Janne
Old 07-12-2020, 05:34 PM
Now if I wanted to check compatibility.... I'd do a clean macOS install on a partition/container on your boot drive or if not room there then on a spare SSD... install of macOS does not take too long and you know you have a perfectly clean install when done to test with.
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Unistall and Install Pro Tools 2020- Questions Zak7 Pro Tools 2020 5 05-06-2020 10:57 AM
new install of Pro Tools 2020.3: two questions dg27 Pro Tools 2020 5 04-11-2020 02:49 PM
Cannot install Pro Tools 2020.3 (macOS) iz_thewiz Pro Tools 2020 1 04-06-2020 12:16 PM
Cannot install Pro Tools 2020.3.0 on Catalina in any which way moyno85 Pro Tools 2020 3 04-04-2020 03:41 AM
