Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 06-25-2020, 06:40 PM
Thenewexhibit Thenewexhibit is offline
Default Consolidating track names that end in C, L, or R???
Hello!
Is there a way to change the behavior of how a track in pro tools gets named when consolidating? I'm doing drum samples, and decided to list the velocities as A, B, C, etc. so that they are organized appropriately.
Problem is, when I get to C, it changes to i.e. "Kick_01 C", where as everything else is "Kick A_01" etc. That makes it a little confusing because when the kick says "Kick_01 C", it's corresponding stereo overhead sample just says "Overhead_01", and I'm assuming it won't label a stereo track with a C (center) at the end of it because it's stereo?? It makes it hard to keep track of all of the C hits.
Another example is with naming a guitar track "GTR L", and when consolidating it, it turns into "GTR_01 L", where I'd prefer it to consolidate as "GTR L_01". I'm assuming it's doing the same with C for "center"?
Is there a way to change this behavior in a preference somewhere?
Old 06-25-2020, 10:45 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Consolidating track names that end in C, L, or R???
No, I don't think there's any way to change how Pro Tools auto-names files. You'd have to rename them - which you can do a batch rename. You're probably right about L, R and C being reserved for left, right and center. Maybe use X, Y, Z instead??
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.9
Old 06-25-2020, 10:58 PM
Got ya! Thanks for the reply! It's so strange that it does that; a bit of a pain! haha
I'll have to look into batch rename! I have to upgrade all of my OS and PT version first, so it may be a minute, but thank you for the heads up! More incentive to do that faster! hahah
Thanks again and God bless!
Mike.
Old 06-26-2020, 08:17 AM
No, you can't change the behavior, but just add an underscore instead of a space before the L,C, OR R and all will behave as you want. IOW, "Kick_C" will consolidate and playlist correctly.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 06-26-2020, 12:41 PM
Oh, good point with the underscore! Thanks for the heads up and God bless!
Mike.
Old 06-26-2020, 03:19 PM
home_studio home_studio is offline
Just remember it changes the names of the clips, not the names of the audio files.
2020.5 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 10.13.6 / MBox 3 Pro / 2 x Artist Mix / PT|Control / Aja T-Tap
Old 06-26-2020, 04:17 PM
cwsand's Avatar
Yes but there's another step you can go through to rename the actual files.
Cntrl-Shft-R for Batch Clip Rename then Cmd-Shft-R to rename the files to the Clip name.
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2020.9
Old 07-02-2020, 07:30 AM
noah330 noah330 is offline
One of the last steps I do before I mix a track is to name all of the audio files what they are _final.
I find by using that it keeps things clean and organized. YMMV
Track names vs Playlist names bredo Pro Tools 10 6 01-07-2013 08:29 AM
Need Region names to remain the same as original when consolidating and exporting! dkstudios Pro Tools TDM Systems (Mac) 0 01-23-2012 09:31 AM
consolidating/file names question capt kirk Post - Surround - Video 2 09-15-2011 08:41 AM
Track Redering/Consolidating. Kon Alexiou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-24-2007 11:21 PM
CONSOLIDATING A TRACK CAUSES CLICKS MOONMAN Pro Tools TDM Systems (Mac) 12 06-09-2005 07:47 PM
