Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-21-2020, 03:11 AM
TNM TNM is offline
Default So.. Cubase Sidechain ADC is a game changer
Hi.. All other DAWs that supposedly have full plugin delay compensation have failed at this (at least pro tools doesn't claim to have any on sidechains).
Cubase 8 and 9 were both 100% broken with sidechain latency compensation, in fact it was easier to work in pro tools cause you could move clips back by samples and saw the delay number easily displayed IN samples.
I am demoing Cubase 10.5 at the moment, just to see whether it's worth upgrading my 9.5 license, and I am blown away.
I put it through HELL and it compensated *everything*.
I just used a simple test with a VI pad, 4 bars, 4 chords, and a dynamics plugin on it, with the dynamics plugin sidechain being fed from an audio track with a simple kick drum loop.
This was a very easy way to test, as I was simply gating the pad with a 4 beat kick, so any fluctuation in timing would be instantly noticeable.
SO..
The only gate plugin I could get with more than 11ms latency was neutron 3..(i could get pro G to 11ms by enabling oversampling and look ahead) and the only way I could do this is by enabling every process in neutron in multiband mode, which got it to 58ms. That way I was able to test the sound when all the previous effects were disabled (they were all just at "flat" settings anyway, only activated to add latency), and then enabled. Of course the gate was enabled at all times. I even made the gate multiband to add that extra latency, but the top band was like in the 15K range so the band doing the work was basically broadband anyway.
Timing was correct at both 3ms latency (the base setting) and 58ms.
So.. I then decided to push it further, and put various latent effects in the same insert path as the gate, before AND after it, and got to around 500ms.. No issues!
So I went one further.. I added a fab filter linear phase EQ to the *kick* track, and it didn't budge.. Just a millisecond burp to readjust quickly.
This is telling me how amazing it is to have sidechain latency compensation. You can basically chuck any latent plugin that affects sidechain and just never have to think about it. I specifically and very heavily limit my choice of S/C plugins in PT due to the lack of compensation.
They say HDX has sidechain ADC. Does anyone know if that's for native AAX as well as DSP, or only DSP? I asked this question ages ago but was unable to get an answer. If it can do native as well, yet another reason I am hanging out to finally upgrade to HDX.
BTW, Logic's sidechain ADC is completely broken in every way, if anyone is wondering.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 02-23-2020, 08:33 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: So.. Cubase Sidechain ADC is a game changer
They also say it works with HDN, but Avid hasn't made a big deal of it. Why don't you take the free trial and try it yourself as you seem to be invested in this?
Janne
Old 02-23-2020, 10:11 AM
XJENSEN XJENSEN is offline
Not true.
Old 03-09-2020, 01:45 PM
TNM TNM is offline
it doesn't.
Old 03-09-2020, 03:32 PM
JFreak's Avatar
Okay then, I've heard baloney
Janne
A Game Changer!!-Pro Tools AS a Rewire Slave-with RME TotalMix!! &collectively64bit! Diccer Pro Tools 10 36 12-08-2018 04:12 AM
"A game changer" EricWillhelm Pro Tools 10 88 10-31-2011 06:58 PM
You see this Guitar? Ernie Ball Music Man 'Game Changer' Demo Benoni Eleven Rack 19 03-24-2011 03:49 PM
Is i7 a game changer for laptops running PT9? betovn Pro Tools 9 2 03-21-2011 07:39 AM
A true game changer... elicious General Discussion 1 08-25-2010 06:01 PM
