Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 07-22-2013, 10:04 PM
pjh567 pjh567 is offline
Default Focusrite Scarlett 2i2/Pro Tools Express Error
I received a copy of Pro Tools Express 10.3.3 with my AKAI MPK49 and have been trying to use it. After installing and registering everything, putting in the I-Lok and plugging in the Focusrite Scarlett 2i2 (again, after installing all of the drivers), I get the following error message when trying to open Pro Tools:
Unable to locate hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is ready.
I'm running Mac OS X 10.6.8 . Any ideas on how to fix this problem?
Old 07-22-2013, 10:10 PM
TimothyJohn TimothyJohn is offline
Default Re: Focusrite Scarlett 2i2/Pro Tools Express Error
Did you get a pop-up instructing you to update firmware? I did. And after updating, my Scarlett 18i20 didn't work. I reinstalled the drivers, and then everything worked fine. Give it a go, just run the Scarlett installer again, restart and try again.
Tim
Old 07-24-2013, 11:11 AM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hello pjh567,
Unfortunately this is a limitation of Pro Tools Express. Avid does not allow use of non Avid Interfaces on Express, only full versions of PT.
The message is stating that it cannot find the Avid Hardware, as there is none connected.
To use the Focusrite device you will need to upgrade to a full version of Pro Tools or choose another DAW to use.
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Focusrite Scarlett 2i2 and Pro Tools 9.0.5 on Win 7 64 Home Premium AndyMVP Pro Tools 9 12 06-04-2015 05:41 AM
Focusrite Scarlett 2i2 Driver issues in Pro Tools 10 jeremyguy Windows 8 10-02-2013 08:54 AM
Pro Tools 9 and Focusrite Scarlett 8i6 - Problems! willyguitar Pro Tools 9 0 11-28-2012 03:57 AM
Focusrite Scarlett justus1900 Virtual Instruments 1 12-18-2009 08:43 PM
