Old 09-14-2011, 10:54 PM
stevegalante stevegalante is offline
Default Elastic Audio and Warp Markers removal
Ok let's say you have a vocal track to do some EA to. You put one plugin (let's say mono or poly), you go into warp view, see the markers PT detected, use just a bunch of them to do your EA and want to remove the others to hear less artifacts possible when rendering the file. Is there a quick way to keep only those you're actually using ? Because otherwise the only way I found is to create a duplicate track, put it in analysis view so you can visually compare them and clean the unnecessary markers, and then apply the EA to this second one.
Thanks
http://www.stevegalante.com
System details :
ProTools Native card, Ultimate 2019.5, MacPro 5,1 12 Core 3.33GHz, 64Gb RAM, Mojave 10.14.4, Lynx Aurora(n), Raven MTi
Old 09-15-2011, 01:54 AM
Stig Eliassen's Avatar
Default Re: Elastic Audio and Warp Markers removal
Can't you go into Analysis view, select all - delete? You've already established the warp markers you want, so that should work, yes?
(haven't had my morning coffee yet, so if it doesn't work I was never here...)
Elastic Audio: Create Warp Markers From Analysis Gatekeeper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-07-2018 07:45 AM
elastic audio - copy warp to another track The Saxplayer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-12-2009 01:15 PM
Copying and Pasting Warp Markers with Elastic Audio dgraham500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-21-2008 12:26 PM
Can't WARP in elastic audio? sureno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-29-2008 02:24 PM
Elastic...adding Warp markers mstucker Pro Tools TDM Systems (Mac) 5 03-03-2008 01:20 PM
