Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-11-2011, 12:47 PM
slater05 slater05 is offline
Default Tear apart my mix?
So i feel that this is the best mix I've done to date... not that I have that many under my belt anyways.
This is one of three songs that I did for the "Advanced" semester at my school. And even though I think it sounds pretty good and I'm proud of it I know that it still isn't at the same level as the pro's.
I'm just looking for some advice on what it's missing to help me keep getting better.
http://soundcloud.com/slater05/pieces
If you like you can also check out the other 2 songs I did at www.mikeslatermusic.com
Feel free to be as brutal as you like as long as it's constructive
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 01-12-2011, 05:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Tear apart my mix?
I'de give you a job if i had one to give
If you've done that on a laptop you've done a stunning job! Well you've done a great job anyway.
Personally would like the snare to be sitting higher in the mix and a bit more defined as a snare sound, i found the mix can fall apart a bit if the snare isn't punching through.
Overall to my taste a bit too much in the 6k-10k region, as the hat and cymbals can be a bit bright and fatiguing at high levels. would go for a bit more 1k-2k region to open the mix out a bit.
The level from soundcloud was -4 dbfs peak? Is your mix that low? i', sure other soundcloud tracks are at full level about -0.3 dbfs
Wrock on....
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-12-2011, 12:31 PM
Thanks for the input!
Sadly I can't say it was all dine on my laptop, although all the editing was. My school has a HD3 system.
I agree with your comment about the cymbals, I neglected them in the mixing process, not that I didn't do anything, they have a gradual low cut, a high cut around 16-17kHz I think, and a couple small dips, but I never really got the piercing quality quite out.
And I do have a snare sample that I made in the mix that gave it that balls that you were missing, but I think I just second guessed it all the time especially on snare rolls where it sounded drum-machine-y.
And that's interesting about the level. I slammed it through the waves LL3 so the snare was hitting -6 GR, but the 'final' copies are being mastered by someone else so maybe the frequency issue and level will be a lot less obvious after that.
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 01-12-2011, 01:21 PM
I think crizdee hit it pretty much for me, although(on my computer speakers) the kick drum has enough tone to jumble the bass guitar(but again, that's on computer speakers).
Old 01-12-2011, 01:42 PM
TOM@METRO's Avatar
One thing that stands out to me is the environment surrounding the snare. It sounds to me, to be in a different room than the rest of the drums. In this musical style I prefer the drums to sound more unified.
All in all though... very nice.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-12-2011, 02:12 PM
It's funny that you say that because the only two samples I added to the drums were a sub-kick to add a little beef, and a snare sample which ended up being buried, so all the drums you hear are the original recorded ones.
Maybe if the snare was up a bit and the drum verb that they are all sent to was a little more prominent it could have fixed that.
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
MIDI making me tear out my hair. Nyx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-17-2011 01:30 PM
Hair tear Faux Pas Pro Tools TDM Systems (Mac) 15 07-08-2003 04:06 PM
Wear and tear. Is my 001 is getting old? keny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-19-2002 12:53 AM
