Old 04-16-2009, 03:30 PM
crizdee's Avatar
crizdee crizdee is offline
Exclamation Using UAD1e card plugins steals all my Native RTAS CPU
I just added some UAD 1e cards but i've noticed that using the plugins is also using loads of the Native RTAS CPU
I don't quite understand why it is using so much of the computers native CPU when it should be using its own processing chips? Basically 10-12 UAD plugins and ALL my native/RTAS CPU is used and this is on an 8-core MacPro
2x UAD1e cards in the computer
Pro Tools cards in the expansion HD
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-16-2009, 04:04 PM
Fidelis Fidelis is offline
Default Re: Using UAD1e card plugins steals all my Native RTAS CPU
I'm sorry to hear that man! I was ready to go for a UAD card but seems a no go right now with HD rigs...
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 04-16-2009, 04:56 PM
rdolmat rdolmat is offline
Originally Posted by crizdee View Post
Chris
And it completely screws up your plugin delay comp...can't really use mine anymore
especially on auxes...
cheers,
rich
Old 04-16-2009, 05:09 PM
crizdee's Avatar
What do you mean exactly? they produce quite a bit of delay, but thats not the problem for me, i can deal with delay, same as i do with Big RTAS waves plugins etc, but i cant deal with the amount of CPU they use.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-16-2009, 07:13 PM
bobo mark bobo mark is offline
Chirs:
i have pretty much same setup as yours. I also have UAD2 and UAD1 in MacPro while the Digi card in Expansion HD.
I'm running very smooth on UAD system, i usually setup the buffer at 512. As i remember i can run about 18 or more UAD plug plus TDM and RTAS. the only problem i have with UAD is im running out of UAD memory faster than UAD DSP power. Since im using 96K session all the time. ( i verified it with UAD tech).
I never have UAD plugins using RTAS power. im on latest UAD 5.3 software.
Regards
Bobo
Old 04-17-2009, 05:30 AM
Chris
Well, try putting the Precision Multiband on an aux....I usually prefer to do this with gang vox (ie: 5 single audio vox tracks grouped into a stereo aux, and throw the Pre Multiband on there)...
not possible
or mayhap I'm doing something wrong?
cheers,
rich
Old 04-17-2009, 06:53 AM
crizdee's Avatar
not possible
With the maximum delay set in Pro tools and your hardware buffer at 512 you should be able to do that ok. placing rtas plugs on an aux will incur more latency than audio tracks but the delay compensation should take care of it. with the max delay compensation set you should be ok for delay up to 4090 samples, not many plugins cause that amount on their own.
But also remember any delay reading on the tracks feeding the aux will be added to it. track delay 2500 samples added to aux delay of 2500 samples = 5000 samples which will turn the reading read and play out of time etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2009, 07:30 AM
Chris
Thanks Chris!!
I'll give that a try today! I've always had my RTAS buffer set pretty high for mixes, but that seems counter-intuitive when using plugin delay..
cheers,
rich
Old 04-17-2009, 04:31 PM
crizdee's Avatar
Originally Posted by bobo mark View Post
Chirs:
This is bizarre i never even looked at the CPU meter with the USD plugins until i got a second card this week and started to do some testing to see how many plugs i could instantiate etc.
And blow me down just 10 uad plugs take up over 50% of my 8-core processing power what are the uad processing chips actually doing then!!!!!
http://www.youtube.com/watch?v=mTAM8mBSzWY
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2009, 11:53 PM
HassanDavis HassanDavis is offline
Chris
Really? I am able to fully max out our UAD1 (PCIe) in PTHD8 with virtually no additional RTAS load on a Quad Core.
You may want to give UA a call...
Hassan
Pro Tools 10.0.1 / OS X 10.7.3 / Mac Pro Quad, 8GB RAM, 1.5TB Seagate Audio Drive / Macbook Pro, 4GB RAM
What exactly are native plugins and do they work on RTAS? chumbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-05-2020 10:54 PM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Do VST and Plugins make use of the HD Native card? Boogie457 macOS 2 12-12-2010 04:30 PM
SSL Duende PCIe card and RTAS plugins DaveSB Pro Tools TDM Systems (Mac) 2 04-26-2008 07:42 PM
DSP card to use plugins as RTAS in Protools 7 LE Urtzi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-10-2006 06:09 PM
