Old 07-26-2007, 12:17 PM
andyaynow andyaynow is offline
Default Laptop issues with Dual Core Processor, please help!!!
Hi I am fairly new to all of this, I got pro-tools 6.4 with the 6.7 upgrade a year ago using the Orginal M-Box hardware. I just recently purchased a Dell Inspiron 1501 with AMD 64 dual core processors. Its running on xp as well. So not thinking I just installed 6.7 on it and got the major blue screen with the BIOS erros and how to change some things, I read on the post about all the issues and how you would need to shut one core down, and still there were issues, but that Pro-tools 7.3 was designed to run on Intel-core duo processors for windows xp laptops. But i wasn't sure about AMD processors, my two questions and I am sure they are very ignorant are
1) If i do the $75 download of 7.3 will it run with my M-Box hardware I already have
2) Will 7.3 run fine on my laptop or will there still be conflict?
Thank you for time and any help you can give!
Old 07-26-2007, 12:19 PM
spkguitar's Avatar
Default Re: Laptop issues with Dual Core Processor, please help!!!
1. Yes
2. you haven't posted enough information about your laptop to answer this question.
Old 07-26-2007, 12:21 PM
spkguitar's Avatar
If I remember correctly, the 1501 comes with either AMD Sempron or AMD Turion processors. Neither is compatible with Pro Tools.
Old 07-26-2007, 12:22 PM
thank you for your help, what info do you need about my laptop, I will get it to you I appreciate this so much
Old 07-26-2007, 12:23 PM
its Athlon
Old 07-26-2007, 12:25 PM
spkguitar's Avatar
  • download and install SiSoft Sandra
  • Run sandra, go to the "Hardware" tab, and run the "Computer Overview"
  • copy and paste the results here
Old 07-26-2007, 12:34 PM
I know I am a complete idiot I feel really stupid and I appreciate your help here! everything on the site is in french
Old 07-26-2007, 12:39 PM
spkguitar's Avatar
On the far right hand side of that website is a column with the header "Langues" (that's languages in french). If you click on "English" below that header... well... everything will be in english.
Old 07-26-2007, 12:42 PM
spkguitar's Avatar
Here's a direct link to the download hosted on the C|net site: Sandra Download
(4th link from the top of the page I already linked you to, and yes, it's in english )
Old 07-26-2007, 12:44 PM
SiSoftware Sandra
System
Host Name : D71Y4BD1
User : Brantley
Workgroup : MSHOME
Processor
Model : AMD Athlon(tm) 64 X2 Dual-Core Processor TK-53
Speed : 1.70GHz
Model Number : 2992 (estimated)
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Low Power, Dual-Core
Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 256kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Platform Compliance : AMD LIVE!
Bus(es) : ISA PCI PCIe IMB USB i2c/SMBus
MP Support : 1 Processor(s)
MP APIC : Yes
System BIOS : AT/AT COMPATIBLE
System : Dell Inc. Inspiron 1501
Mainboard : Dell Inc. 0UW744
Total Memory : 894MB DDR2-SDRAM
Chipset 1
Model : Dell Computer Corp RS480 Host Bridge
Front Side Bus Speed : 2x 800MHz (1600MHz data rate)
Memory Bus Speed : 2x 14MHz (28MHz data rate)
Chipset 2
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Total Memory : 1GB DDR2-SDRAM
Memory Bus Speed : 2x 242MHz (484MHz data rate)
Video System
Monitor/Panel : Default Monitor
Adapter : ATI Radeon Xpress 1150
Physical Storage Devices
Hard Disk : WDC WD1200BEVS-75RST0 (112GB)
CD-ROM/DVD : TEAC CDRWDVD DW224EV (CD 24X Rd, 24X Wr) (DVD 3X Rd)
Logical Storage Devices
Hard Disk (C:) : 109GB (101GB, 93% Free Space) (NTFS)
CD-ROM/DVD (D:) : N/A
Peripherals
Serial/Parallel Port(s) : 1 COM / 0 LPT
USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
USB Controller/Hub : Standard OpenHCD USB Host Controller
USB Controller/Hub : USB Root Hub
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Synaptics PS/2 Port TouchPad
Communication Device(s)
Device : Conexant HDA D110 MDC V.92 Modem
Printers and Faxes
Model : Microsoft Office Document Image Writer
Model : Fax
Power Management
Mains (AC) Line Status : Off-Line
Battery No 1 : 64%
Operating System(s)
Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2)
Platform Compliance : Win32 x86
Network Services
Adapter : Broadcom 440x 10/100 Integrated Controller
Adapter : Dell Wireless 1390 WLAN Mini-Card
Performance Tips
Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.
Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? okodub Pro Tools 9 3 09-23-2011 07:33 AM
AMD Dual-Core Processor ? Munir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-20-2008 08:43 PM
XP: Core 2., Dual Core, 2 Processor Board, what is up? Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-11-2007 06:29 AM
Windows Laptop Compatibility - duo core processor smackeroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-07-2007 06:03 AM
Dual Core V Dual Processor Support Red Box 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-18-2005 05:22 AM
