Old 07-25-2007, 03:59 PM
Colorblind Colorblind is offline
Default -9073 errors
Hey all,
I'm running a decent sized session (40 or so tracks, not a ton of plugs), and when I try to bounce to disk, it gets about 3 minutes and 20 seconds in and I get the "DAE can't get audio from the drives fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or CPU load -9073" error.
I'm running PTLE 7.3 with a 002r on a MDD Dual 1.25ghz G4 with the RAM maxed out. OS 10.4.8. My firewire drive is a Maxtor 120GB with Oxford 911 chip, partitioned into three 40GB sections. Can anyone help me get this solved? Thanks in advance,
C
Old 07-26-2007, 12:54 PM
Default Re: -9073 errors
After doing some searching, I changed my DAE buffer from 2 to 8, and tried to bounce again. This time it got through the whole song, but then I got an Assertion error saying the bounce failed. I then set my DAE buffer to 4, bounced again and it seemed to work fine.
C
Old 07-27-2007, 12:46 AM
FOX digital FOX digital is offline
Colorblind
maybe this helps. Had the same issues with -6085.
http://duc.digidesign.com/showthread...=&sb=5&o=&vc=1
Since i turned Dashboard off, there's no problems (knock on wood) anymore.
Tell me if it works for you.....
All the best
Claude
System: MacBook Pro 10.4.9 Combo Update | DuoCore 2 2.33Ghz | 2GB RAM | 160GB HD | digi 003 | PT 7.3.1cs4
dae errors 9073 Shotty capogne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-10-2010 07:05 PM
PT8-9073 errors gone? mtung Pro Tools TDM Systems (Mac) 32 03-11-2009 06:59 AM
9073 Errors jwoodsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-08-2006 02:31 PM
9073 errors Bookerv12 Pro Tools TDM Systems (Mac) 2 09-13-2001 11:29 AM
9073 errors JLEpperson Pro Tools TDM Systems (Mac) 0 11-27-2000 06:24 AM
