Old 02-12-2007, 10:29 AM
Colorblind Colorblind is offline
Default Resetting I/O settings TDM -> LE
Hey all,
I'm running PTLE 6.4 through a 002 rack, and using an Alesis AI-3 to add 8 more channels via ADAT. I recently opened some sessions that were done using Pro Tools TDM, and some of my I/O settings were changed. Now I can't figure out how to use my tracks 9-16 via adat anymore. When I click on interface, it says: >Mic/Line 1 (mono) etc..
>Analog 5 (mono) etc...
Then after Analog 8 where it used to give me my ADAT choices, it says:
>In 17 (Mono) - path n/a
>In 18 (mono) - path n/a etc...
I tried to sort this out in my I/O settings, but I'm really getting nowhere. Can someone help me? I'm PT challenged. Thanks in advance,
C
Old 02-12-2007, 10:37 AM
comprodman's Avatar
comprodman comprodman is offline
Default Re: No ADAT input option
One way round this is to open a new session and import session data from that session, you will bet all the info and data from that session and you will be in your normal LE environment, so you will then be able access all the data you want.
Living on a Narrowboat in the Middle of nowhere
Old 02-14-2007, 06:04 PM
Morley Morley is offline
http://tinyurl.com/26y44n
Try this.
LE 7.4, MacPro, 3 GHz, 4 GB
Old 02-16-2007, 09:11 AM
Hmmm.. tried those options. When I create a new session, I'm still getting the I/O settings of the TDM system. Can anyone help me? Thanks,
C
Old 02-17-2007, 10:46 AM
bump
Old 02-17-2007, 11:06 AM
Slim Shady Slim Shady is offline
uh...
have you tried going into I/O settings and hitting the 'default' button on the input tab?
Old 02-18-2007, 09:40 AM
Yep, that works to restore my original settings. But when I create a session, I still get the TDM settings. Is there some way I can create sessions without having to change my I/O setup every time? Thanks again,
C
Old 02-20-2007, 07:08 AM
Anyone?
Old 02-20-2007, 07:11 AM
smsjr smsjr is offline
Yes, when you create a new session, select your default I/O setup in the New Session dialogue window.
Steve
Resetting take numbers kelsey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-14-2010 09:01 PM
Sends resetting soundguydave Post - Surround - Video 1 03-12-2007 05:41 PM
Resetting a HUI? studiomusic Digidesign Hardware & Software 0 06-26-2003 01:14 PM
Fader not resetting ernstg ICON & C|24 4 07-15-2001 12:18 AM
'resetting' Plugin settings ? Arno Peeters Pro Tools TDM Systems (Mac) 1 09-05-2000 09:12 PM
