Old 05-01-2006, 09:50 PM
mwerden mwerden is offline
Default coreaudio output with digi hardware
If I go into the audio MIDI setup for digi hardware it only recognizes 2 outputs. This happens at work on our HD 3 rigs (6.9 on OSX 10.3) and at home with my 002 (LE 7 on OSX 10.4). The digi coreaudio driver sees all ins and outs, and the audio MIDI setup sees all the inputs. For whatever reason Audio MIDI setup only sees 2 outputs . Any thoughts or, dare I ask, workarounds?
Old 05-01-2006, 09:58 PM
Default Re: coreaudio output with digi hardware
PS - our HD3 rigs at work use 192s
Old 05-04-2006, 12:18 PM
No one has any thoughts on this at all? Am I wrong in assuming that this is happening because OSX isn't seeing what the digi coreaudio driver sees? Anybody?
Old 05-08-2006, 10:31 AM
DigiTechSupt's Avatar
Try trashing preferences files, including Digidesign Core Audio Manager.plist and com.apple.audio.audiomidisetup.plist, empty trash, restart and try again.
Avid Audio Tech Support
Support FAQ
Old 05-09-2006, 07:07 PM
Trashing prefs didn't work. Has anyone ever even seen OSX recognize the outputs for digi hardware? I would like it to work, but I'm not entirely convinced it will. I'm just trying to get more info.
Old 05-10-2006, 11:05 AM
Yes, I see what you mean now. I believe this is a limitation of AMS, as other applications will recognize more than 2 outputs when using Core Audio.
Support FAQ
Old 05-11-2006, 12:00 PM
Right, I figured that was the case. Thanks for the info.
PT9 with Digi Hardware: DAE or CoreAudio? lagasus Pro Tools TDM Systems (Mac) 0 11-13-2010 09:02 AM
Help! Digi 002R, OSX 10.4.8 - CoreAudio Can't find hardware jdimoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-25-2007 07:37 PM
iTunes audio output through Digi hardware? Audiodude Pro Tools TDM Systems (Mac) 3 05-17-2006 10:13 PM
No audio output in Logic with digi coreaudio crizdee Pro Tools TDM Systems (Mac) 2 11-07-2005 01:04 AM
Classic Mode Audio Output Thru Digi Hardware? flymax Pro Tools TDM Systems (Mac) 3 08-04-2004 04:02 PM
