Old 08-02-2005, 01:30 PM
carrow carrow is offline
Default READY TO PULL MY HAIR OUT!! *MIDI Question*
I use Steinberg Groove Agent (and about 10 other VST) plug ins in PTLE 6.4, Win XP, via FXpansion's VST to RTAS wrapper, which in itself works beautifully most of the time.
Groove Agent has a "MIDI OUT" and "MIDI GM OUT" function but no matter how I configure my MIDI track in PTLE, I cannot get the MIDI to record. I have no trouble getting the audio to record -- but no MIDI. Steinberg says it's supposed to work, somehow, but they don't explain anything other than how to do it in Cubase in the manual. I have no trouble, either, recording MIDI data from my hardware synth when i use it as a controller for my VSTs.
I also tried to get ANY MIDI to record from MIDI-out VSTs, with no luck.
Life would be so much easier if this worked. Has anyone else had any luck? Is it even POSSIBLE to record MIDI data from VSTs? Thanks.
Old 08-02-2005, 01:37 PM
jstunner jstunner is offline
Default Re: READY TO PULL MY HAIR OUT!! *MIDI Question*
I don't have grove agent but I don't think PTLE supports this yet. If you can't find "Grove Agent" channels in the midi input menu, then my guess PTLE doesn't support it. It would be cool if it did, BFD has a "midi" out, but I know that doesn't work in PTLE.
Old 08-02-2005, 01:39 PM
soundsurfr soundsurfr is offline
Have you tried just exporting the midi file from your VST and importing it into PT?
Soundsurfr
MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM
M-Audio Firewire 1814
Yosemite OS
Old 08-02-2005, 01:56 PM
Actually, in the MIDI input menu, "Groove Agent" shows up just fine, like all the other VST instruments.
Groove Agent 1 (the version I have) won't export MIDI. The new one does, but I can't spring for the upgrade yet.
Old 08-02-2005, 02:09 PM
spkguitar's Avatar
According to Angus from FXPansion, the wrapper does not support MIDI out.
See this thread
Old 08-02-2005, 02:17 PM
Well, now I know. Amazing how long I looked, but got the answer in 10 minutes from the good folks on this board.
As an aside, can anyone suggest a way to record MIDI from Groove Agent into PTLE 6.4?
Old 08-03-2005, 03:06 AM
Angus_FX Angus_FX is offline
FXpansion Audio
The only way you might be able to do it is to run Groove Agent inside a VST host like Bidule (www.plogue.com) and connect it to Pro Tools via a "virtual MIDI cable" like Hubi's MIDI Loopback Device or Midi-Yoke.
Angus F. Hewlett, CEO
FXpansion Audio - http://www.fxpansion.com
Quick question about file conversion before I pull the rest of my hair out Imagine Nation General Discussion 1 02-20-2011 07:17 PM
Core Audio drivers make we wanna pull my hair out!!!!! mikezilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 01-25-2009 07:30 PM
How to deselect tracks. About to pull out my hair! Aten Pro Tools TDM Systems (Win) 1 12-01-2007 06:26 AM
going to pull my hair out.... drdavis74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-04-2007 03:33 PM
Protools m-powered... going to pull my hair out!!! DYNAMIK Pro Tools M-Powered (Win) 3 10-13-2005 06:01 PM
