Old 02-17-2020, 12:52 PM
pherzfeld pherzfeld is offline
Default Re: Gui Lag in 2019.10 on OS 10.13.6
Any other ideas? I have yet to try running without plugins as the issue appears at random and sometimes not for a while so Im gonna have to have some serious downtime to try that.
Old 02-17-2020, 12:59 PM
Meads Meads is offline
I've had these GUI lags on all kinds of computers and I have never been able to pinpoint it 100%. But it was never a CPU or other performance issue.
My recent Hackintosh - for whatever reason - is the first and only machine I've used where I didn't experience this lag. I wish I knew why, but unfortunately I don't. Nothing changed periphery or software wise.
However what I've noticed when those lags occured was the following:
There's a process running in the background of MacOS called "WindowServer". It handles all kinds of display activities. If you force quit it from activity monitor you're being kicked out of MacOS back to the login screen. BUT - it consistently solved the lag for a while. Just logged back in again and everything was snappy.
It's feels like some kind of graphical memory leak (don't quote me on that).
Give it a try, sure won't hurt anything.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 02-17-2020, 01:46 PM
JFreak JFreak is online now
Sure. Killing the display manager reverts you to command line interface. Lucky that OSX has automatic restart of dislpay manager so you don't (normally) have to do anything to get GUI login.
Old 02-17-2020, 01:50 PM
You don't, and whatever helps, right?
Obviously you shouldn't mess with processes required by the system, and this shouldn't be the solution for the problem. But in this case it is, and I prefer a re-login to a painfully stuttery PT GUI.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-17-2020, 02:03 PM
Right. Slightly faster than cold reboot which UNIX should never have to do, except when you update kernel.
Old 02-17-2020, 02:06 PM
Quite a lot faster. It's instant.
Still, it shouldn't be necessary at all and I wish I knew what causes this behavior in the first place. I sank hours into that, and I'm really glad I found this "dirty fix".
If anybody has a cure I'd gladly take it. I'm just fighting a symptom.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-17-2020, 02:10 PM
If it's a memory leak, nothing cures it except OS update (that fixes window server or graphics driver)
Old 02-17-2020, 02:14 PM
I don't know, I've posted this back in Feb 2018 for the first time and had experienced it long before that post:
http://duc.avid.com/showthread.php?t=397516
I've seen lots of OS updates, none of which fixed the issue.
And with my current system at home I'm using the same OS (10.14.6) as on my iMac Pro at the studio. The iMac Pro does have the issue, my Hackintosh doesn't.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-17-2020, 02:20 PM
And which GPU (graphics drivers) are we talking about? Hackintosh itself does not explain the (lack of) issue, only software does.
Old 02-17-2020, 02:30 PM
But I've had the same issue with NVidia GPUs on10.13 and below.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
2019 iMac vs 2019 Mac Pro Peterjk Pro Tools HDX & HD Native Systems (Mac) 7 01-14-2020 12:23 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
