Reason - Recording Monitoring Issue
Hi folks,
Here's my issue: In my current PT 8 session, I have 5 tracks: click, vibes (instrument track from Miroslav Philharmonik), bass (instrument track from Reason), drum loop (from PT Audio Library), and master fader. I've laid down an upright bass part sound from Reason's NN-XT Sampler via ReWire mode in M-Powered Pro Tools 8, overtop the drum part - no issue. However, when I go to track the vibes part, I hear the Reason bass instrument playing simultaneously with the vibes. When the bass track is record enabled AND when it isn't record enabled, I hear it. The main level fader shows a level on the bass meter when I play on my keyboard (AxiomPro 61), but does not show any level on the meter at the top of the track slot near the top-most I/O selectors. Just to check things out, I tracked a take of the vibes (with the bass sounding), and upon playback, all is well - the vibes tracked fine AND without the bass. However, during tracking, I cannot seem to stop the bass from sounding. If I mute the bass track, it doesn't sound during playback (obviously). I know it's probably a Reason monitoring issue, but cannot figure out how to solve this - I'd appreciate any help! Thanks, M |
Re: Reason - Recording Monitoring Issue
You have to disable your keyboard/MIDI input in Reason Preferences when in ReWire mode, as it's getting input from it directly as well as via Pro Tools.
Hi there,
Thanks for the suggestion - how exactly is that done? I'm still getting my footing. Thank you, Matt |
Let me make sense of that answer, for I use Reason as well.. Are you saying while in ReWire Pro Tools is the only thing allowed to use a midi controller, and Reason it must be disabled, as if you were not using a midi controller for it at all?
MacBook Pro 2.16 Intel Core 2 Duo, OSX 10.6.2, PTM-P, Reason 4, Logic Pro 9, M-Audio Axiom 25, M-Audio Ozone, M-Audio StudioPro 3, Audix OM-2, Ibanez, Peavey: PR12 (2), PV-6, PV 900 |
I strongly advise reading the entire Reason manual, so you know where to find these settings (and everything else in Reason) in the future. |
Yes, that is correct. Otherwise if you press a note on your keyboard, you will get the note input into BOTH Reason and Pro Tools. Pro Tools then routes that note to Reason via ReWire, resulting in double-triggered notes or conflicting on/off note messages.
Ahh, yes - there's that option.
Thank you everyone for your help! Matt |
Thank you for your help! |
Reason 2.5 + PT + low latency monitoring | bzldzl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-25-2004 11:17 AM |
Low Latency Monitoring with Reason 2.5 | jiagap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-23-2003 08:10 PM |
monitoring Reason through Mbox? | wendyF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-10-2002 12:03 AM |
monitoring reason | fnky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 03-21-2002 08:28 AM |
monitoring reason | fnky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-19-2002 12:56 AM |
