Audio Tracks Not Working
I am having Audio/Vocal Track problems.
I had a vocal track that has been laid for sometime, no problems hearing it on playback in the past. Than all of a sudden when I hit playback I can no longer hear it. Not only this but when I try and record a vocal track, anywhere in protools 8 le, any template, it does not record my voice at all, or get a playback from a already laid vocal track from the past. Midi is fine, its just audio/ vocal that the problem out of the blue. I uninstalled protools 8 le and reloaded it thinking it might be a audio driver problem but it did not correct the problem. I have compatible O.S. HARD DRIVE, M BOARD/ CHIPSET, RAM, Dedicated Video card, CPU. Any Ideas, Thanx Much. |
Re: Audio Tracks Not Working
We need much more information.
What Avid (Digidesign) hardware are you using? What are your I/O settings for the problem audio tracks? Are you using a master fader? Which monitoring mode are you in? (auto-input? or input only? switch using alt + k). I'm probably forgetting a few questions. Also, even though you say and think your computer and peripherals are compatible, they may not actually be. You might want to post a Sandra report as instructed in the General Troubleshooting post to be sure.
Elastic Audio Not Working on Some Tracks | hybridd | Pro Tools M-Powered (Mac) | 10 | 07-20-2012 01:55 PM |
PT10: Import tracks with overlay+match tracks not working | Frank Kruse | Post - Surround - Video | 3 | 12-02-2011 09:06 AM |
Elastic Audio -- Not Working On ALL tracks? | tommydigiowen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-29-2008 11:54 AM |
aux tracks not working | 21fm | Tips & Tricks | 2 | 07-12-2005 11:07 PM |
Bouncing Midi Tracks to Audio Tracks ...Latency? | kirk95 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-27-2004 06:54 AM |
