Will my laptop even work with PT 8LE?
I have a Gateway P-6860FX and tried installing PT 8LE with an Mbox 2 on my laptop. I know Windows 7 isn't even supported yet but I tried anyway since some were having success getting it to run with a USB interface.
The install goes fine, but when I reboot when prompted I get a PACERegister error 3. When I try to run PT as admin I get another error that says Code -7 and a failed to initialize 0xc0000142. I am thinking that something is going wrong with the PACE part of the install. I tried updating to PT 8.0.1 and updating the PACE software but I still get the same errors. I have an InterLok folder in my C:\Program Files (x86)\InterLok but that folder was empty. Not sure if that has anything to do with it. I did the install as compatible with Vista Service Pack 2 and ran PT as admin. I would like to get this working on Windows 7 64bit but I am now wondering if my laptop will even work with PT. I am posting a Sandra report and would like to know if my system will even work with PT if I had a supported OS. Thanks! SiSoftware Sandra Computer Model : Gateway P-6860FX Workgroup : WORKGROUP Host Name : laptop User : David Processor Model : Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz Speed : 1.83GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : Gateway P-6860FX BIOS : Phoenix Technologies LTD R01-A1P (94.29.00) 03/10/2008 Bus(es) : X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR2 SO-DIMM Chipset Model : Gateway 2000 Mobile PM965/GM965/GL960 Express Processor to DRAM Controller Front Side Bus Speed : 4x 166MHz (664MHz) Total Memory : 4GB DDR2 SO-DIMM Memory Bus Speed : 2x 332MHz (664MHz) Memory Module(s) Memory Module : Samsung M4 70T5663QZ3-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M4 70T5663QZ3-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : NVIDIA GeForce 8800M GTS (64 SM4.0 1.25GHz, 512MB DDR3 2x864MHz, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD3200BEVT-22ZCT0 (320GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 298GB (C:) (D:) Generic-Multi-Card 8GB (USB) : 7GB (F:) WDC WD5000BEVT-22ZAT0 (500.1GB, USB/SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 466GB (G:) Optiarc DVD RW AD-7563A (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 283GB (NTFS) @ WDC WD3200BEVT-22ZCT0 (320GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Removable Drive (F:) : 7GB (FAT32) @ Generic-Multi-Card 8GB (USB) Local Disk (G:) : 466GB (NTFS) @ WDC WD5000BEVT-22ZAT0 (500.1GB, USB/SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Recovery (D:) : 15GB (NTFS) @ WDC WD3200BEVT-22ZCT0 (320GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Optical Drive (E:) : N/A @ Optiarc DVD RW AD-7563A (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Gateway 2000 ICH8M (ICH8) LPC Interface Controller LPC Legacy Controller 1 : T0 FC-11h Audio Device : Gateway 2000 82801H (ICH8) HD Audio Controller Serial Port(s) : 3 Disk Controller : Gateway 2000 82801H (ICH8) Ultra ATA Storage Controllers Disk Controller : Gateway 2000 ICH8M (ICH8) 3 port SATA Controller USB Controller 1 : Gateway 2000 82801H (ICH8) USB UHCI #4 USB Controller 2 : Gateway 2000 82801H (ICH8) USB UHCI #5 USB Controller 3 : Gateway 2000 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : Gateway 2000 82801H (ICH8) USB UHCI #1 USB Controller 5 : Gateway 2000 82801H (ICH8) USB UHCI #2 USB Controller 6 : Gateway 2000 82801H (ICH8) USB UHCI #3 USB Controller 7 : Gateway 2000 82801H (ICH8) USB2 EHCI #1 FireWire/1394 Controller 1 : Lucent/Agere Systems (Was: AT&T MicroElectronics) FW322/323 IEEE1394 OHCI FireWire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MP620 series Printer (Colour) Scanners and Cameras Scanner : Canon WIA Canon MP620 ser_000085F437CF (Scanner, USB) Peripherals Media Player : Generic- Multi-Card (7.4GB) Network Services Network Adapter : Realtek PCIe GBE Family Controller Wireless Adapter 1 : Intel(R) Wireless WiFi Link 4965AGN (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7100 Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Re: Will my laptop even work with PT 8LE?
Sorry dap,,,,,,, Your drives are too slow,,, 5400 rpm and only 8 MB cache. And your 2nd drive for recording is the same with usb,,,, usb being a no go!! You need a firewire (approved) drive,, and bothe drives should be 7200 rpm, with a minimum of 16 MB cache, (32 MB cache prefered for 8.1)!!!
Good Luck,,,,,,,,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
I understand the issue with the drives. I just want to make sure this system will even load up PT (as of now it won't even start) before investing more $ into new drives. I plan on getting 2 7200 RPM internals.
I've got exactly the same proble with my workstation. Mbox 2 pro. PT 8.0.3 works perfectly on Windows 7 x86 Ultimate... switching to Windows 7 x64 Ultimate there's no way to get protools running. P.S. my drive is a raid0 of a couple of 7200rpm drives....
will this old laptop work? | legacygt777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-15-2010 07:27 PM |
what laptop will work for me? | lostwaveproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-21-2008 06:03 PM |
Will the M-box work with my laptop? | Siren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-06-2006 02:39 PM |
WIll my laptop work? | slicksrs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-20-2003 08:46 AM |
will PT LE work on a laptop? | VanEdge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-25-2000 01:30 PM |
