Old 05-16-2009, 03:37 PM
digidesigner digidesigner is offline
Default SC48 how much dsp is in there?
At the glance I did not see that info anyhere.
Old 05-16-2009, 04:35 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: SC48 how much dsp is in there?
2 DSP Cards.
Same as a standard Mix Rack.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 05-16-2009, 05:07 PM
Originally Posted by Chris Lambrechts View Post
2 DSP Cards.
Chris
Thanks Chris! Also in the video they say 20 TDM plugin slots does that mean 20 plugs in total on channels inserts and send-return effects combined? Any other limitations or fine-print regarding that matter?
Old 05-16-2009, 05:51 PM
emluper emluper is offline
20 plug in slots total, but how many plugs you can use depends on how much DSP those chosen plugs consume. There are a total of 18 DSP chips and some of those are used for the mix engine. I would try setting up a show with the 2.8 standalone software set for SC48 and see how many chips are left for plug ins.
The thing is that the Venue line is capable enough with the onboard eq and dynamics that you could get away with only using the plugs for harmonizers, delays and reverbs. I would go in this direction first, see what I have left and then think about the esoteric plugs.
Old 05-22-2009, 08:14 PM
BradLyons BradLyons is offline
As mentioned, there are (2) DSP cards in the SC48 and that is fixed---NOT expandable. And while there are (2) DSP cards in the MixRack system that is expandable to a third card....the Venue MixRack, Profile, and DShow use about 1 1/2 cards to process the console where the SC48 really is using about one whole card to maybe 1 1/2. The (20) TDM plugin limit really is a fail-safe, so to speak. When I first went over the SC48 I thought this was a limitation----then again I realized, what other console in this price point can do such a thing..... nuff said.
Thank you,
Brad Lyons
www.howavl.com
Old 05-23-2009, 10:21 AM
eytan eytan is offline
Hi Brad,
Does that mean that there are 20b types of plug-ins available or are there 20 plug-in slots in the rack?
Old 05-23-2009, 02:53 PM
Rockpolice Rockpolice is offline
Originally Posted by eytan View Post
Hi Brad,
It means that there are 20 slots and the amount of plug-ins depend on the plug-in itself. Some of them use a whole slot by themselves and some use only 10-15% of a slot.
I haven't yet checked the SC48 offline- editor, but really raw guess would be, that there are the normal 100 plug-in rack slots available to put as many different plug-ins that you have authorization to if they just aren't that dsp-intensive?
Music business is serious business.
Old 05-23-2009, 05:00 PM
amoyer amoyer is offline
From what I have seen on the offline editor, the SC48 has 20 plug in slots, no more.
Old 05-23-2009, 05:07 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
The number of plug-ins that can be run at once on a VENUE system depends on two factors: the amount of DSP available for plug-ins, and the number of rack slots available for instantiating the plug-ins. Depending on the combination of plug-ins in use it's possible to use up the available DSP before filling all rack slots; it's also possible to fill up all rack slots before using up the available DSP.
The SC48 comes equipped with a maximum of two DSP cards; each card has 9 DSP chips, for a toal of 18 DSPs. These cards do the basic mixing and also run plug-ins. You can tailor how much DSP is used for each function on the Options > System page (even on the Standalone software). Reducing the number of input channels or GEQs gives more DSP for plug-ins. As a general guideline, a single DSP chip can run one or two high quality reverb, delay, or channel strip emulator plug-ins, and five or more compressor or EQ plug-ins. (It's a bit more complicated than this, but this gives a rough idea).
Plug-ins instantiated in the rack can be inserted on channels or used as bus-fed effects, such as reverbs and delays. For example, you could have 18 compressor or EQ plug-ins for inserts (in addition to the built in channel EQ/Comp/Gate), plus a reverb and a delay, for a total of 20 plug-ins. Each channel can have up to four plug-ins - chosen from the rack of 20 plug-ins - inserted.
The number and type of plug-ins available to choose from depends on the plug-ins installed on the console. A plug-in doesn't use DSP until it's installed in the plug-in rack, so you can always have more plug-ins installed than in use.
Sheldon
Old 05-24-2009, 12:41 AM
Ooops. My bad. Next time i'll not guess. Sorry for that.
SC48 and SSD S-ACU VENUE Live Sound Systems 10 10-21-2022 01:36 AM
SC48 to DP or other DAW? brookfloyd VENUE Live Sound Systems 1 08-03-2013 11:42 AM
Sc48 fwx pt9 lmiller VENUE Live Sound Systems 3 03-18-2013 03:39 AM
GPI on SC48 TheMAXX7 VENUE Live Sound Systems 3 03-18-2012 12:11 PM
Sc48+pt le braxty VENUE Live Sound Systems 4 04-18-2010 11:00 PM
