Greetings,
This is a work in progress, however I wanted to start in on the discussion of patching different types of IO into MTRX family devices and determining the appropriate delay values. Here's the start of that. Please note that all of the Digi Delay values being used here are 7 samples - which is the default when you have the monitor section (Pro|Mon) enabled on MTRX with a monitor profile loaded. We can discuss more on that - but for now I would always recommend using the 7 sample value for consistency. Hopefully this will be a helpful starting place before we can get some of this put into an article on the Avid Knowledge Base. [MTRX Studio] 44.1kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 1.27ms 44.1kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.18ms 44.1kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.17ms 44.1kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 5.39ms 48kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 1.18ms 48kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.16ms 48kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.16ms 48kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 5.13ms 88.2kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 0.62ms 88.2kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.09ms 88.2kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.08ms 88.2kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 3.68ms 96kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 0.57ms 96kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.08ms 96kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.07ms 96kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 3.6ms Ferrofish Pulse 16 for analog expansion via ADAT -> DA + DA -> ADAT 44.1kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.75ms 48kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.70ms 88.2kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.37ms 96kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.34ms 96kHz: MTRX Studio Dante -> MTRX Dante -> MTRX Studio = 2.18ms 96kHz: MTRX ST -> MTRX -> DA AD -> MTRX ST = 2.75ms The last 2 here are somewhat experimental but show how to patch in an analog compressor connected to MTRX in another room uplinked via Dante. [MTRX] 44.1kHz: MTRX: AD -> DA, Hardware Insert Delay = 1.15ms 44.1kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.16ms 44.1kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.23ms 44.1kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.13ms 48kHz: MTRX: AD -> DA, Hardware Insert Delay = 1.00ms 48kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.14ms 48kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.23ms 48kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.13ms 88.2kHz: MTRX: AD -> DA, Hardware Insert Delay = 0.56ms 88.2kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.08ms 88.2kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.11ms 88.2kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.06ms 96kHz: MTRX: AD -> DA, Hardware Insert Delay = 0.51ms 96kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.07ms 96kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.10ms 96kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.05ms 48kHz: MTRX: AES -> PCM96 -> AES, Hardware Insert Delay = 1.28ms 96kHz: MTRX: AES -> PCM96 -> AES, Hardware Insert Delay = 1.11ms Jeff |
Jeff!!! This is awesome. Thank you so much!!!
Avid S6M40-32-5D, MTRX (2), Barefoot MM26, PT Ultimate HDX3, CB TMC1 S6 Penta |
Do these apply both to the MTRX and MTRX Studio?
https://lukehoward.com/ |
These are MTRX Studio only. I'm going to fill in the other rates and repeat the drill for the flagship MTRX as well. Stay tuned.
Jeff |
Worthy of stickie status
Many thanks |
Agreed on both points!
Thanks for this Jeff!
Scott Gatteño |
Thanks for this Jeff.
It would be very, very helpful for this to be automatically calculated, or for there to be a roundtrip 'ping' type plugin (like the IO plugin in Logic) to save a lot of faffing about.
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid HDX, MTRX, DAD AX64, DAD AX24, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com Music: https://www.euclideancircuits.com |
Good idea!
G
Composer/Sound Designer/Protools 2023.3 Ultimate, Avid MTRX. DADMAN MOM Monitoring,Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Network Headphone Amp, DVS,MADI, Mac Studio Ultra, 128 RAM/4TB SSD, Monterey12.6.6, Digital Perf11.2.2, Logic Pro X 10.7.8 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
To keep updated.
Regards |
You can hit Thread Tools -> Subscribe, rather than posting.
MTRX-> HDX or MTRX->Dante | ArmyofLight | Pro Tools | MTRX & MTRX Studio | 34 | 04-08-2021 04:51 PM |
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card | antonis | Buy & Sell | 9 | 04-11-2020 06:47 AM |
Where are all the delays?! | Southsidemusic | Pro Tools 11 | 27 | 01-14-2014 06:36 AM |
Help with Tap Delays | soundbobby | VENUE Live Sound Systems | 2 | 04-01-2010 03:28 PM |
WHY DELAYS ? | EejayDray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-17-2005 03:05 PM |
