Old 06-01-2013, 08:25 AM
mentalsanityoff mentalsanityoff is offline
Default Consolidating Fades
I'm experiencing this odd issue regarding the consolidation of two audio regions with a crossfade. When consolidating these two regions, the fade seems to lose a bit of power towards its center. I've attached screenshots of the visual representation of the problem, but I can definitely hear the difference as well. What's up with this? The region in question is a forest ambience, pretty wide-range noise.
Julian Evans
composer | sound designer | musician
www.julianevans.info
http://www.imdb.com/name/nm4227580/
Old 06-08-2013, 10:06 PM
MaxVelazquez MaxVelazquez is offline
Default Re: Consolidating Fades
If you have pt10 use clip gain to resolve it. I really don't have a clue why that would happen.
Bikers never get lost....We go sight seeing
Old 06-09-2013, 02:22 PM
Stig Eliassen's Avatar
Looks like a standard equal power crossfade, and consolidated duplicates null completely here on my mobile rig. All kinds of crossfades also null here, for that matter. Naturally, I can't hear any difference either.
Can't really help you, other than to tell you that I've tested various x-fades, duplicates and files here, and I don't see what you're seeing.
Old 06-09-2013, 06:37 PM
Tweakhead Tweakhead is offline
If you do the same section as a realtime bounce at unity gain, what does it look and sound like?
Old 06-10-2013, 10:05 AM
P,B,S P,B,S is offline
Originally Posted by mentalsanityoff View Post
the fade seems to lose a bit of power towards its centre.
You do realize that crossfades are not duct tape.
They do not glue one section to another.
A crossfade to deduce noises made from separate clips or regions works because it fades out at one end of the clip and fades in at the start of the new clip. Thus the losing power. Because thats exactly what it is supposed to do.
If this is causing problems for you it is because the fade is to long.
Try shortening the cross fade small as possible while remove the unwanted noise. Cross fades are not really meant to last any longer than they have to be.
Old 06-10-2013, 03:58 PM
Irl Sanders Irl Sanders is offline
Seems like you are drawing a positive parabolic equal power cross fade, but getting the results of a negative crossfade. Here is pink noise crossfaded all three ways, with proper visual (and audible) results.
Do you have clip gain on your in and out regions? Maybe the fade isn't picking up on that? Aside from a bug, maybe the two regions are partially phase canceling with each other? Try nudging one the regions a few hundred samples, and see if you get the same result, or fade at a different part of the file. Is it just these two particular regions, or anything you try to xfade? Could the file itself be corrupt? Check with Disk Utils.
The rendered results look the same wether consolidated or AudioSuite Duplicated
Irl Sanders
Music Editor
LA, CA, USA
PT 11.1.2 Crashes when consolidating, adjusting fades, Audiosuite auditions etc Michael Carpenter Pro Tools 11 9 09-30-2016 11:06 AM
Loud White noise fades on fades and dissolves! www Pro Tools 9 2 04-16-2013 09:59 AM
Fades prefs vs. Batch Fades (or beating a dead horse) Starcrash Post - Surround - Video 2 09-23-2008 03:40 PM
create fades batch fades issue pt le theom Tips & Tricks 4 07-24-2006 09:46 PM
fades on muted regions render active fades?! yikes clarpark Pro Tools TDM Systems (Mac) 11 02-08-2004 04:49 PM
