Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-11-2018, 08:30 AM
leomartins leomartins is offline
Default recomendations: non-HD interfaces for pro tools 12
Hi I have a Mac OSX 10.11.6 El Capitan with pt 12.8.2. Someone have recomendations of compatible non-HD interfaces? Preferably with usb connection, good price, good phone output and the smaller number of i/o possible.
Thanks!
Old 04-11-2018, 09:47 AM
amagras amagras is offline
Default Re: recomendations: non-HD interfaces for pro tools 12
What kind of work are you planning to do?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-12-2018, 05:12 AM
Edit sound for movies
Old 04-12-2018, 10:08 AM
So you're going to need at least 6 outputs for 5.1 mixing(which means HD or "Ultimate" software). Focusrite, MOTU, Antelope and RME are all solid options. If you want to use UA Plugins, then Apollo moves to the top of the list
Old 04-13-2018, 06:04 AM
I dont need 6 outputs. just one. I work with phone. Its not for mixing, just edit dialog and backgrounds. I have ultimate software. Thanks for the recomendations Albee! And its not for recording too. So I just need one out for phones and a usb connection.
In other words i need the most simple option, that works fine with OSx 10.11.6 and pro tools ultimate 2018.4 and a good cost bennefict!
Old 04-13-2018, 06:35 AM
Use the onboard audio of your computer
amagrasmusic.com
Old 04-14-2018, 10:29 AM
VRW VRW is offline
Thanks!
Even if this little box does offer more than you seem to need its unbeatable as for its sound quality in this price range and its definitely working with Pro Tools 12/2018.
It´s plug n play, class compliant which means you don't need any driver and under normal circumstances it is a very stable little interface with PT12. Big Bang for the buck.
https://www.sweetwater.com/store/det...e-scarlett-2i2
https://global.focusrite.com/usb-aud...s/scarlett-2i2
If you really don't need any inputs but very high output quality and you want it really small, this one might be something for you. However, even if it might be worth the price
in regards to its audio quality, it is not the most affordable thing in the world.
https://www.sweetwater.com/store/det...-headphone-amp
http://www.apogeedigital.com/products/groove
Again, the Apogee doesn't need any drivers, which is a very good thing, its just plug n play and it does work with any Mac computer.
Cheers.
Old 10-19-2018, 10:56 AM
wildplum wildplum is offline
I would like to better understand why it is that HD is considered better than “non-avid interface” Pro Tools for tracking.
Is it because the avid hardware (e.g., a 192 I/O) is faster at access information of the computer’s recording disc than a non-avid interface?
Is it because the avid hardware has faster converters than the non-avid interface/converter?
Is it because, when using plug-ins while tracking, the DSP on the avid interface provides better performance? Is this still true if you do not use plug-ins during tracking?
Or is it because of some other reason that I have no idea about- what is that other reason?
I am asking because I face that inevitable decision. After having used Pro Tools for tracking and editing for over 16 years (most of that in a TDM environment), I have to decide whether to spend big bucks on a new HD system or go with a non-avid interface version. I use Pro Tools for tracking and editing (and, on occasion, for sharing stuff with other studios). I mix analog (on rare occasions, I do mix ITB; but that is not often enough to factor into my decision) and I do not see that changing anytime in the near future.
Paul Tumolo
Wildplum Recordings
a micro label, studio and remote recording service
Old 10-19-2018, 12:25 PM
BScout BScout is offline
The DSP is on the HDX cards, not the interface.
If you use only AAX-DSP stuff (plugins), in essence all processing is happening on the cards (mixer and plugin processing) and the system will have the smallest latency of any system. If you use native plugins, then that changes.
The latency of Avid hardware is programmed into Pro Tools so Pro Tools will automatically compensate correctly for it (both inserts and inputs). Many third-party audio interfaces that connect via the same HDX (digilink) connectors emulate not only being an Avid interface but the delays of the Avid hardware to take advantage of this compensation.
Interfaces for pro tools 12 matty-obcd macOS 1 04-06-2016 12:15 PM
Traditional Avid interfaces vs 3rd party interfaces aftermid Pro Tools 10 9 10-24-2012 01:12 PM
Pro Tools Installation Recomendations? michaelpair74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2010 10:48 AM
New Pro Tools HD Interfaces Escape 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-19-2010 08:17 AM
interfaces for pro tools 7 Illl0lll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2006 11:26 PM
