Old 01-04-2024, 03:23 PM
ihate100bees ihate100bees is offline
Default orig MBox 1 with Mac Book Pro (Ventura)
My grandson just bought a new Macbook Pro with Ventura 13.5 I have an orig Mbox 1 that I thought in 2006 that he could use to start out with, since it's an all in one box. Has anyone got this combination to work? What will I need to download and install? Drivers, software, etc.. Thanks
Old 01-04-2024, 03:32 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: orig MBox 1 with Mac Book Pro (Ventura)
It will not work. You would need Pro Tools 8 LE, which only runs on PPC systems.
Janne
Old 01-04-2024, 03:44 PM
Ok... I do have the orig Mac 6.9 LE software for MAC OS X. Can't I download the final version of the MAC LE software for this box? I was going to try using the Ploytec audio driver. What do you think? As an registered buyer I should be able to download the last version of software that was released. Thanks
Old 01-04-2024, 03:47 PM
JFreak's Avatar
Last PPC systems were sold in 2005. You need PPC system to run those ancient versions. Will not work on your new computer.
Janne
Old 01-04-2024, 04:06 PM
Ok. My orig receipt is dated 4/17/06. I see there are a few others that were able to get it to work. I'll keep checking. Thanks.
Old 01-05-2024, 08:05 AM
smurfyou smurfyou is offline
You will probably get comments about how crazy it is to try to use something that old.
I'll refrain because I don't mind using old things that still work - HOWEVER the original MBOX is truly not worth the hassle.
1) it's just not great at anything it does
2) As pointed out it needs an ancient version of PT which will never run on modern Macs
3) If you manage to get the Ploytec driver working you still have to get a modern version of PT
So with that, you're better off avoiding the hassle and picking up literally any modern USB 2X2 interface. Behringer would be an improvement. I'm positive you could find several options under $100 that will be way more useful.
~Will
Old 01-05-2024, 09:29 AM
JFreak's Avatar
Nope, it doesn't work like that.
Back in the day, DigiDesign sold major and minor upgrades. Going from PT 6.9 LE to PT 8.x LE would require major upgrade, which you obviously cannot buy any longer.
Only free updates were 6.9.x level updates.
Janne
Getting Orig Mbox to Run on PowerBook G4 kage65 Pro Tools M-Powered (Mac) 3 11-03-2009 01:18 AM
Orig mbox 1 supported by PT8? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-12-2008 02:01 PM
Mac OS X 10.4.10 and Mbox (orig.) floridah2o 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-26-2007 01:11 PM
How noisy is the Mbox 1 Orig?! buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-18-2007 06:51 AM
Mbox Orig as ASIO soundcard? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-17-2006 01:16 AM
